02-20-2012, 03:52 PM | #1 |
Model A Drop Axle w/Stock Brakes
Anyone know if a 2" or 3" A drop axle be used with stock Model A mech brakes?
02-20-2012, 04:20 PM | #2 |
Re: Model A Drop Axle w/Stock Brakes
I believe that Ed Johnson runs stock brakes with a dropped axle. You would need to make an extension for the spring perch where the brake lever assy connects.
02-20-2012, 04:22 PM | #3 |
What are you going to do with the stock mechanical brake levers? You might have to extend your perch mounts or?
02-20-2012, 04:22 PM | #4 |
Purdy just beat me to it.
02-20-2012, 05:08 PM | #5 |
Thanks everyone.
Also, anyone know what reverse eye and leaf removal would drop to? Is this a better/easier way to go to lower the car? |
02-20-2012, 05:58 PM | #6 |
Reverse eye spring will lower car 1.5". I'd be careful removing too many leaves at the front. The starter spring will flatten out as you reduce the spring pack and at some point will bottom out on top of axle. Winter over yet up there? Fred |
02-20-2012, 06:07 PM | #7 |
Thanks CT AV8
PM info sent. |
02-20-2012, 06:35 PM | #8 |
There was an article 4-5-6 years ago in street rodder mag where it showed installation of a dropped axle retaining the mech brakes. I have it but don't know where. Maybe someone else can help or try posting on the EV8 forum. Funny, I was just thinking about this article over the week-end.
Paul in CT |
02-20-2012, 06:42 PM | #9 |
Thanks Paul.
Now that you mentioned it...I also remember that article and I also have it. Thanks for reminding me of it. I believe they did another article on the same Tudor lowering the rear and then adding juice brakes. |
02-20-2012, 07:11 PM | #10 |
Go to the dark side and you will find lots of info.
02-20-2012, 07:29 PM | #11 |
Paul in CT
I found a Rod and Custom Feb 09 issue having an article about lowering a Tudor but it is the juice brake conversion at the same time. This the one you are referring to? |
02-20-2012, 07:47 PM | #12 |
It would be greatly appreciated if you could post the information on that article as I am doing the same thing to my 30 Victoria. I thought you could use 32 spring perches but I am ot sure that's the answer.
02-20-2012, 08:03 PM | #13 |
Here's the article. They are doing juice brakes at the same time....not what I'm after.
http://www.rodandcustommagazine.com/...dor/index.html I think 450 x 16 tires on wires front then 550 x 17 tires on wires, reverse eye, leaves removed front and rear will give me what I'm looking for w/o the need for a drop axle. |
02-20-2012, 08:35 PM | #14 |
Sent P.M.
02-20-2012, 09:20 PM | #15 |
Here is a link to a good thread on lowering the A.
http://www.fordbarn.com/forum/showthread.php?t=12576 Bob |
02-20-2012, 09:44 PM | #16 |
Thanks Bob C.
02-21-2012, 02:32 AM | #17 |
08-21-2012, 03:33 PM | #18 |
2935,
I know this is an old thread but we just did it on our '30 coupe and I posted some pics on JJ. It can be done. |
08-21-2012, 06:50 PM | #19 |
The key is to replace the A spring pearches with those from a 1932 Ford. Check the HAMB for a detailed discussion on the change. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
08-21-2012, 06:57 PM | #20 |
CT AV8 thank you.
How do you like it? Roadster62 or 33/34 perches, I think. |
