08-25-2020, 08:07 AM | #1 |
Leakless or not? Never mind! Found my answer.
How can you tell if you have the "leakless" type water pump?
I have a '29 Coupe that I purchased and the previous owner did not know much about the car. Is there a way to tell? Well, a little more research tells me the answer......if it's not leaking it's leakless So, I won't worry about it. I believe my noise issue is from my fan. When I replaced the steel 2 blade with an aluminium 2 blade I may not have tightened the nut down enough. Also discovered the gen bolt was loose.....all fixed up now! Last edited by 2935ford; 08-25-2020 at 03:26 PM. |
08-25-2020, 01:15 PM | #2 |
Re: Leakless or not? Never mind! Found my answer.
The leak less pumps that I've used were noisy unless I used water pump lubricant in the radiator .
08-25-2020, 05:03 PM | #3 | |
08-26-2020, 09:12 AM | #4 |
Thread Tools | |
Display Modes | |
