Old 04-10-2021, 03:04 AM   #1
Graham Freeman
Default 1933/34 dual gauge temp sender unit (hose part).
Hi guys,
I am looking for the part on a 1933/34 dual gauge (new or used) that clamps thru the radiator hose that accepts the sender unit.
Are these being reproduced at all?
Thanks
Graham
Graham Freeman is offline   Reply With Quote
Old 04-10-2021, 05:38 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1933/34 dual gauge temp sender unit (hose part).
At one time they were,not anymore. No market for them.
Old 04-10-2021, 09:23 AM   #3
deuce_roadster
deuce_roadster's Avatar
Not that long ago I got what you are talking about from Randy at a gauge place in Arizona.
The same place that can repair the temp gauge part.
Old 04-10-2021, 10:15 AM   #4
petehoovie
petehoovie's Avatar
Originally Posted by Graham Freeman View Post
Hi guys,
Thanks
Graham
Old 04-10-2021, 10:25 AM   #5
deuce lover
Thanks deuce roadster , I totally forgot about Randy at RS Gauges.
Old 04-11-2021, 11:03 PM   #6
Graham Freeman
Well I contacted Randy but he is out of stock and his supplier is closed due to Covid, I am not sure if it is temporary or for good.
So, is someone able to post or message me some close up picture and dimensions so I could look at having one made.
Thanks in anticipation.
Graham Freeman
Old 04-12-2021, 08:38 AM   #7
uncle buck
uncle buck's Avatar
Don't the 35-36 and aftermarket water pumps have a threaded port in them?
File Type: jpg F966AB34-5401-465A-BB79-4B4E6B5C284F.jpg (72.0 KB, 63 views)
File Type: jpg 486030F7-68CE-4257-B180-0D312CCF4178.jpg (96.8 KB, 91 views)
File Type: jpg B23E6B95-E074-4535-9379-465657592CF7.jpg (72.0 KB, 59 views)
uncle buck is offline   Reply With Quote
Old 04-12-2021, 08:45 AM   #8
uncle buck
uncle buck's Avatar
Bob Drake’s water pumps
Old 04-12-2021, 08:45 AM   #9
David J
David J's Avatar
Yes but they are female thread .
The 33-34 fitting is male thread .
David J is offline   Reply With Quote
Old 04-12-2021, 08:53 AM   #10
uncle buck
uncle buck's Avatar
I see that now in my gauge picture
Old 04-12-2021, 01:24 PM   #11
fourfords
fourfords's Avatar
OOps
fourfords is offline   Reply With Quote
Old 04-12-2021, 03:23 PM   #12
deuce lover
Originally Posted by fourfords View Post
Gauge Works, Randy Stebbins 602-928-1746
Read post #6. Out of stock.
Old 04-12-2021, 03:37 PM   #13
Graham Freeman
Thanks guys but I need details of the piece that takes the bulb that clamps into the hose.
Old 04-12-2021, 04:39 PM   #14
DavidG
DavidG's Avatar
Graham,
I believe that this is what you are seeking. Please let know if you want the various dimensions.
Old 04-12-2021, 05:15 PM   #15
Graham Freeman
Thanks David,
Yes exactly what i am looking for.
Some close up pictures and dimensions would be great.
Regards
Graham Freeman
Old 04-12-2021, 05:27 PM   #16
Andy
The common lower hose heater hose fitting looks similar. Maybe one could be modified?
Andy is offline   Reply With Quote
Old 04-13-2021, 08:42 AM   #17
uncle buck
uncle buck's Avatar
I was thinking the same thing
Old 04-13-2021, 10:22 AM   #18
DavidG
DavidG's Avatar
Graham,
Most of the originals that I have encountered were made entirely of brass with the part that fits inside the radiator hose cast to create a lip surrounding the threaded portion to affect a good leak proof seal. Some have steel hex nuts rather than brass.
The dimensions are as follows:
-- the base of the threaded portion that fits inside the radiator hose is 1 1/4" x 1 5/16" with the latter running front to back (I've several and all have that minor variation in their overall dimensions). The raised cross section at the top of the curve from the end view is 9/32". The radius is that of the inside of a upper radiator hose although it works equally well in both V8 and larger B outlet hoses. The 11/16-14 threaded portion is 3/4" and the overall height is 1 1/4". The recessed area above the threads is 3/32" and the inside of the opening at the top is slightly countersunk.
-- the outer portion measures 1 1/8" x 1 1/8". The hole in the center is 3/4". The thinnest cross section is 1/16" thick and the thickest cross section is 3/16"
-- the 11/16-14 hex nut is 1/4" thick and 31/32" across the flats although others have a nut 1 1/8" across the flats.
I'll try for better photos later today, but for the best quality it would be best if I sent them via email. For that, please p.m. me your address.
Old 04-14-2021, 03:59 PM   #19
Graham Freeman
David,
Did my email address get to you yesterday by PM?
Graham
Old 04-14-2021, 04:22 PM   #20
mercman from oz
mercman from oz's Avatar
1933/34 Dual Gauge Fuel and Temp Sender Unit.
