01-29-2015, 11:14 PM | #1 |
oil bath air filter
i am about to restore my oil bath air filter and plan on using the molasses bath method to remove the rust.knowing that this method will not remove old oil or grease does anyone know of a degreaser i could use to soak and clean the filter before before doing the molasses bath? also have oil stains on concrete driveway,what can i use for that.
01-30-2015, 12:54 AM | #2 |
Re: oil bath air filter
Totally immerse your parts in Simple Green, full strength. Get a big bucket from home depot etc. put the part in it and cover the part with Simple Green, leave it a day or more, rinse with water and if it is still greasy drop it in again. Works great.
I have never tried molasses so I can't speak to that but i have used Evap-O-Rust. Applied in the same manner as I prescribed for the the Simple Green it will do just as they claim.
Ignorance of the laws of physics does not mean they do not apply to you. Last edited by 29AVEE8; 01-30-2015 at 01:04 AM. |
01-30-2015, 08:58 AM | #3 |
Start with the hotest water on the first soaking. Will cut the heavy grime a lot quicker.
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
01-30-2015, 01:05 PM | #4 |
29,thank you,i have some walmart super clean hangen around here,do you suppose it will work as well,should i dilute with water or full strainght? thank's gmc,are you referring to the molasses bath or both and what would be the ratio? thank's again to you both..
01-30-2015, 02:04 PM | #5 |
See if you can find a large crockpot or electric roaster at a thrift store for a few bucks. Pretty much any degreaser, cut with water, will work wonders when used with heat. I've a $2 crockpot that has cooked many carburetors and other grimy parts.
I dig coal, which provides motivation for EVs. |
01-30-2015, 02:05 PM | #6 |
01-30-2015, 04:28 PM | #7 |
muriatic acid works great on concrete, make sure to wear your rubber gloves and glasses. You can dilute if you like. You can use a broom or a long handles scrub brush, rinse with garden hose when done.
Thank God this is only a hobby! |
01-30-2015, 04:37 PM | #8 |
and what ever you do keep your nose an mouth away from the fumes Very toxic ,,,, mikey mason
01-30-2015, 05:27 PM | #9 | |
For the grease on the driveway just wet it then spray simple green full strength wait a few minutes, if the concrete has a "grain" like it was broom finished get a very stiff bristled brush (not a wire brush) and brush with the grain, wait some more, rinse. Repeat as necessary. This stuff is not too harsh on your skin but I would wear eye protection, don't think it will play well in your eyes.
Ignorance of the laws of physics does not mean they do not apply to you. Last edited by 29AVEE8; 01-30-2015 at 05:51 PM. |
01-30-2015, 05:44 PM | #10 |
This works like a charm,just don't use one of the wife's good crockpots!!
01-30-2015, 06:23 PM | #11 |
I know not everyone has a solvent tank, but if it were me, I'd buy a gallon of solvent and a stiff bristled brush and use a bit of elbow grease to clean it out..., the use a piece of window screen inside a funnel and pour it back into the can...toss the screen, keep reusing the solvent.
I hate having to wait for things i want clean of grease/oil packed dirt, etc. |
01-30-2015, 10:31 PM | #12 |
Many oil bath aircleaners have a chamber inside for sound deadning ---the chamber doesn't get liquid in it normally, not easy to drain out, anything like acid, or media blasting won't come out, if it is rusty inside there most likely the only way to get the rust out---and whatever is used to clean out the rust, and the debris from cleaning the rust will only come out by taking the aircleaner apart at the seams, into componet parts, personally if my oilbath aircleaner is internally rusty I would look for a different one.
If only the external surfaces need cleaned I would use wirebrush, sandpaper, solvent, perhaps gasoline---if the aircleaner suffered from neglect(too low of oil level) dip clean the mesh with solvent, or gasoline |
01-30-2015, 10:46 PM | #13 |
jiw1,
What vehicle is this air cleaner fit? As for cleaning mine, I use the aerosol brake cleaner and it spiffys up right quick. I avoid the cleaner that is "green" and good for the environment. Use the real stuff, OUTDOORS, in the fresh air and still wear eye and mouth protection. |
01-31-2015, 01:33 AM | #14 |
01-31-2015, 11:00 AM | #15 |
good morning guys,thank's for all the suggestions.i like the crock pot idea.will be going out today to find one. thirt4 sorry i did not mention year or model. i am working on two.one is from my 1950 f5 that has a mercury tea pot carb and the other is a 50-53 mercury with a 90* elbow moving the oil bath off to the passenger side of carb.i see what you mean about the sound chamber.there is a threaded hole in both unites for a support bracket to intake manifold which will drain liquid from the chamber.both unites have HH stamped in on the bottom.anybody know.thanks to all for welcomed advice,john
01-31-2015, 11:03 AM | #16 |
will try to send some pictures later.have to figure it out how to do it first.
01-31-2015, 11:12 AM | #17 |
Oven cleaner ! On both counts . Let stand 10 minutes repeat then wash with water .------after concrete dry add dry dirt will pick up stain in time . Get oven cleaner at 99 cent store quality care brand best .
01-31-2015, 11:48 AM | #18 |
I would do what Mike B suggested then water blast it ,quick and easy
01-31-2015, 03:24 PM | #19 |
Read the first post on this subject slowly! He asks about cleaning stains on his driveway. LOL
01-31-2015, 09:06 PM | #20 |
here are some pictures.
