10-08-2011, 10:59 AM | #1 |
Front Service Brake(s) Adjustment
Is the Front Brake adjustment at the "actuating arm" accomplished with the weight of the car on a flat surface or while up on car jacks? When I adjust the brake drag while the car up on car jacts the wheel spins with no noise. When I put the car down on pavement the front wheels make a loud scraping noise when I attempt to move the car, more so when I apply the brakes. I put on new cast iron drums and hubs and all new parts and have adjusted the brakes several times. What is going on? How do I fix it?
Bill Lee/Virginia Peninsula |
10-08-2011, 12:32 PM | #2 |
Re: Front Service Brake(s) Adjustment
It sounds like you have too much slop in the front wheel bearings and tightening them may help. Else or in addition, I think you have to look at worn spindles (where the inboard bearing rides) or drums that were installed out of alignment with the axis of the hubs.
10-08-2011, 02:37 PM | #3 |
First things first.. The stands are under the axles and not the frame ?
10-08-2011, 02:39 PM | #4 |
Rich:
Thank you. The inner wheel bearing was very loose within itself, in fact made the whole drum plain sloppy. I purchased it from a national parts house last spring but could not find any mfg markings or part numbers on it at all. I used the old, mabye original bearing I saved from the previous rebuild and it now works as it should. I appreciate your time, info and advice. Bill Lee/Virginia Peninsula |
10-08-2011, 02:53 PM | #5 |
Patrick:
Thank you for the safety reminder. I was born and raised in a family owned machine shop near Charlotte and my Dad always had what he called "A 5 Minute Safety Meeting" before pay checks were handed out on Fridays. I sincerely appreciate your concern. Bill Lee/Virginia Peninsula |
10-09-2011, 07:08 AM | #6 |
