08-24-2020, 12:51 PM | #1 |
Steel head gaskets
What do I put on a 21 stud steel head gasket with cast iron heads to get a good seal?? Copper coat,grease,or silver paint or nothing
I used copper coat on a composit gasket the other day,had a stuck valve,and removed head and gasket came apart,Joes had the steel for $20 !thoight I would try them,,,
DON P |
08-24-2020, 01:01 PM | #2 |
Re: Steel head gaskets
Don, I have built countless flatheads and have applied copper-coat to each and every head gasket.
I would not consider anything else. It works - period.
08-24-2020, 04:33 PM | #3 |
Same here on v8s and 4cyl Ts
08-24-2020, 04:44 PM | #4 |
I always just use a good grease on all gaskets. Never had a problem with seal and they are easy to remove. My 2¢. Tell me why I'm wrong.
08-25-2020, 05:33 AM | #5 |
Coctacted fel pro tech line! Also ,,,guy said copper coat or there was another sealer I forgot,!,,
DON P |
08-25-2020, 06:09 AM | #6 |
08-25-2020, 08:47 AM | #7 |
If everything is clean and FLAT it does not matter whether you use a sealant or what type sealant. I have used aluminum paint, copper coat, and nothing without problems when iron heads are installed.
Torque nuts in several even increments and DO NOT over-torque. Go through at least 3 hot-cold engine retorque cycles and drive forever. |
