08-22-2017, 01:18 PM | #1 |
max1 isky
Hi Guys. Can i use stock valve springs with an isky max 1 cam in an otherwise stock 8ba? Thanks, mike
08-22-2017, 02:09 PM | #2 |
Re: max1 isky
If they are the Ford springs and if they are not shimmed into coil bind, yes.
08-22-2017, 03:22 PM | #3 |
Re: max1 isky
I don't see why not. I use stock springs withe the L-100 and a .060" shim
08-22-2017, 06:42 PM | #4 |
Re: max1 isky
Been using them in mine for a little over 30 years. Working great.
08-23-2017, 06:49 AM | #5 |
Re: max1 isky
Thanks JWL, Ron, and 4t8v8 for the "short & sweet" replies on the valve spring / Max 1 issue. Much appreciated !!! mike
08-23-2017, 08:17 AM | #6 |
Re: max1 isky
