08-05-2019, 01:14 AM | #1 |
Schrader valve stems
Are inner tubes available that use the Schrader valve stems?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-05-2019, 08:38 AM | #2 |
Re: Schrader valve stems
If a person gets the rubber stem tube, the stem can be carefully cut off for installation of the OEM style Schrader valves. I've not yet seen a tube come with the OEM style valves.
08-05-2019, 02:29 PM | #3 |
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
08-06-2019, 11:35 AM | #4 |
I ordered tubes not long ago that had this very kind of valve stem. They were available everywhere.
08-06-2019, 04:13 PM | #5 | |
Most new production tubes I have used have the brass stem molded into a rubber vulcanizing pad. Outwardly they look like the old style. It should also be noted that the bridge washer is very important on either style of brass stems. Without it the stem is easily pulled out of the tube in use.
Jack Innes, Brooklin, Ontario |
08-06-2019, 05:52 PM | #6 |
08-07-2019, 07:33 AM | #7 |
To add to what Jack correctly said the currently available tubes with metal valve stems do not fit Model T wood felloe wheels because the stems are larger in diameter than the hole in the ferrule. If your wheels have been re - wooded in the past ten years or so by Stutzmann they use a large enough piece of tubing (5/8" OD, 1/2" ID) to allow these new, larger metal stems to fit.
These new metal valve stems are not re - usable like originals. They are vulcanized in place. They are not made to be reusable. This is why original metal valve stems are superior. They can be re - used endlessly by purchasing a rubber stem tube, cutting off the rubber stem, and inserting it. It's super easy to do.
08-07-2019, 08:05 PM | #8 |
I have the stems. I was just hoping to find correct tube that don't require surgery.
08-08-2019, 10:22 PM | #9 |
08-10-2019, 09:14 PM | #10 |
The ones with rubber stems are much like what was available back in the day, except they are made from modern silicone rubber that doesn't take patches well. It takes less than 5 minutes to install a stem. Super easy.
08-09-2019, 10:00 AM | #11 |
Royce posted some info here;
http://www.mtfca.com/discus/messages/599638/640373.html This is a pretty good description of how to do it; http://sheepisland.com/cars/tech/metal_stems/
I know the voices aren't real but damn they have some good ideas! |
08-09-2019, 02:15 PM | #12 |
As long as you are not the one requiring surgery��
08-11-2019, 09:07 AM | #13 |
Tubes in the model T time frame were vulcanized natural rubber. After the war, the butyl rubber took over. Now that more tubes are being used for radial tires, they are using later technological formulas to take the heat better. Most are still chlorobutyl elatomers. Elastormers for the inner lining of tires and inner tubes may be using a halogenated isobutylene-co-paramethylstyrene polymer in some applications.
So far, I haven't seen any that use fluorosilicone polymers yet but who knows what is coming from Asia these days. When I go to Harbor Freight stores, I can smell some kind of nasty synthetic rubber smell in most of them. |
