Old 01-16-2021, 04:44 PM   #1
flathead 53
Default Period correct fire extingusher
I have a period correct brass fire extingusher with mounting bracket , it was dealer item from ford , iwould like to mount it someware on my restored 53 f-100 , i have an antique potter trunk mounted in the bed ,thinking about next to it , would like to display, it , any ideas ?
flathead 53 is offline   Reply With Quote
Old 01-16-2021, 05:26 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: Period correct fire extingusher
The ones I've seen were mounted on the floor by the driver's door.
Old 01-16-2021, 05:33 PM   #3
19Fordy
19Fordy's Avatar
I'm no expert but make sure it's filled with the correct Fire Extinguisher Substance for a car fire. I have heard Halon is the best but, is not period correct. I guess you could carry 2.
Old 01-16-2021, 05:46 PM   #4
1942deluxe
1942deluxe's Avatar
I was an USAF firefighter and halon was a great agent but I think banned today because of concerns for the ozone. Did it's job and then dissipated . I think we're stuck with dry chem
today which makes a royal mess and creates corrosion.
Old 01-16-2021, 06:10 PM   #5
ford38v8
ford38v8's Avatar
Your legal but corrosive dry chemical extinguisher might well be converted to storage space for a good upgraded fire insurance policy. 🤨
Alan
ford38v8 is online now   Reply With Quote
Old 01-16-2021, 07:38 PM   #6
Bob C
Looks like now they have Halotron.
Old 01-16-2021, 07:43 PM   #7
alanwoodieman
the old pump fire ext. were Pyrine? or something akin to it, would put out a fire and remove any color that happened to be near it and aspixiate you in the process
Old 01-16-2021, 08:07 PM   #8
woodiewagon46
The accessory "Fire and Tire Unit", that was offered in '46-'48, was filled with carbon dioxide gas. The mounting bracket did not come with the extinguisher but was available at extra cost. I have seen them mounted on the passenger side kick panel. If your extinguisher is from the '50s I would think it is also charged with carbon dioxide.
woodiewagon46 is offline   Reply With Quote
Old 01-16-2021, 08:42 PM   #9
51504bat
51504bat's Avatar
Install it next to the trunk for display per your initial thoughts and get a modern ABC rated extinguisher in case you need it. Install somewhere you can get to it easily and relax knowing you have an extinguisher if you need it but hope you never do. JMO.
Old 01-16-2021, 09:37 PM   #10
Lawson Cox
Lawson Cox's Avatar
What about a picture of your truck, showing the bed/trunk et al.
Old 01-16-2021, 10:47 PM   #11
19Fordy
19Fordy's Avatar
I found this statement on the internet Google. Halotron is also available.
"While the production of Halon ceased on January 1, 1994, under the Clean Air Act, it is still legal to purchase and use recycled Halon and Halon fire extinguishers. In fact, the FAA continues to recommend Halon fire extinguishers for aircraft."
Old 01-16-2021, 11:44 PM   #12
Don Rogers
Don Rogers's Avatar
Which one do you have? The Ford one would be post war 40's and the Fomoco would be after that. Early 50's?
Don Rogers is offline   Reply With Quote
Old 01-17-2021, 12:00 AM   #13
Newc
Newc's Avatar
Yea; the old WW 2 Carbon Tet pump type? Puts out the fire and you. Newc
Newc is online now   Reply With Quote
Old 01-17-2021, 07:43 AM   #14
flathead 53
Thanks , the one that I have is the the one from the fifties , I do have A modern fire extinguisher mounted in the cab. this vintage one is empty just for show , Im still thinking about mounting it in front of the potter trunk on the bed floor.
Old 01-17-2021, 09:24 AM   #15
alanwoodieman
newc, that is what I was think about. we had them mounted on every fork lift for years until we started using battery powered fork lifts!
Old 01-17-2021, 09:48 AM   #16
Don Rogers
Don Rogers's Avatar
You could always make your own!!!!!!!! Har, Har, Har!!
Old 01-17-2021, 11:31 AM   #17
37 Cab
37 Cab's Avatar
I have this one mounted to the passenger kick panel in my Cabriolet. And a dry chemical extinguisher behind the seat should I ever need one.fire.jpg
Tommy
37 Cab is offline   Reply With Quote
Old 01-18-2021, 02:27 PM   #18
corvette8n
corvette8n's Avatar
Originally Posted by 37 Cab View Post
I have this one mounted to the passenger kick panel in my Cabriolet. And a dry chemical extinguisher behind the seat should I ever need one.Attachment 453101
I have one that looks like that, but it’s painted olive drab, not sure where my Dad got it, but it was hanging on his garage wall since 1960, it’s empty now for display only.
Old 01-19-2021, 08:45 AM   #19
PeteVS
PeteVS's Avatar
When I was a kid we had an old brass fire extinguisher in the basement. Dad said it was filled with carbon tetra chloride. He said that when it was used, it releases phosgene(?) gas that can be deadly. I think that the carbon tet isn't too good either.
