09-19-2021, 05:30 AM | #1 |
Tuning issue - updated
For those that were following:
Fixed the vacuum leak at the back of the carb. Put the #50 jets back in. Changed to new spark plugs. Checked the timing Oh, does anyone know of a specific distributor wrench that is easy to use on the Y-block? Mine is one huge pain in the rearend, If you have one that you use and know it works good, where'd you get it - I want one too. Haven't had a chance to road test it yet. Weather has been a bit 'unstable', shall we say. |
09-19-2021, 06:39 AM | #2 |
Re: Tuning issue - updated
I just use an appropriate sized 1/4" drive socket with a long extension. Still a bit of a PITA but it does work.
This would work better: https://www.amazon.com/AMPRO-T71255-...2054814&sr=8-6
Often wrong but never in doubt. Last edited by Dobie Gillis; 09-19-2021 at 07:36 AM. |
09-19-2021, 09:06 PM | #3 |
Dobie, would you believe that is the exact dist wrench that I am using...and HATE?
I almost lost half of it down over the back of the engine/trans. |
09-19-2021, 09:23 PM | #4 |
What a coinkydink! Well, I guess the other alternatives are to use my method (1/4" drive ratchet w/long extension), or invest in a set of crow's feet for a 3/8 drive ratchet and a long extension. I'm out of ideas after that.
Often wrong but never in doubt. |
09-20-2021, 02:52 AM | #5 |
https://www.toolsource.com/distribut...8-p-51104.html
Cheaper versions @ HARBOR FREIGHT, SEARS, etc.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
09-20-2021, 02:56 AM | #6 |
Somebody should make a large thumbwheel or wingnut replacement where needed. |
09-23-2021, 07:09 AM | #7 |
So, this is what we call 'fun'? Now it's like the distributor hold down bolt has froze up. None of my fancy-pants wrenches will make it turn -EIHER way....so tonight, I will cram my big hand and a 7" long combo wrench in the hole and see if direct muscle can move it.
wish me luck... |
09-23-2021, 08:24 AM | #8 |
I suggest copious amounts of your favorite penetrant before trying to loosen the bolt. Good luck!
09-23-2021, 08:41 AM | #9 | |
09-23-2021, 10:47 AM | #10 |
Au contraire mon ami .....dist housing rotates easily...no sweat.
The Pertronix ignitor works fine, but I do recall a caution that it could change timing as much as 10 degrees, so I'm resetting it...or trying to... Let's pretend that I have rotated the housing as far as it can go and am still needing more rotation- How mush of a PITB is it to pull the dist up, and 'back rotate' it to gain more adjustment? I put the motor together, but can't recall the mechanism... |
09-23-2021, 11:01 AM | #11 | |
Now let me get this right ... CRS ... The DIST moves freely but the hold down bolt is over-torqued? Who did you get to tighten it down, MAGILLA GORILLA? Yes, you can move a DIST housing by one or more teeth to clear but first I would make sure the thing is installed correctly and that requires a piston stop and chain verification. Is this a FORD DIST or CHI-COM? BTW - A DIST WRENCH was one of the first things I bought off the MAC TRUCK. I don't have the time and/or patience to fiddle with misc make-shift tools.
09-23-2021, 01:54 PM | #12 | |
Anyhoo, before you proceed does this situation ring a bell? Just something to beware of, just wanted to point that out. That little 2c clip on the oil pump drive rod is there for a reason, and many people have discovered this the hard way. Now, to avoid pulling the distributor, you could just move all the spark plug wires over one socket. The distributor itself doesn't really care which terminal is "#1" so long as the plugs are in proper firing order. But, the "clocking" has to allow for sufficient mechanical clearance of the housing back and forth to and fro, to set the timing. As you've discovered. My ODC does not allow for this kind of debauchery! So you'll have to pull the distributor out if you want to get everything setup according to Hoyle. Hold your tongue just right, and allow for some Kentucky windage because of the helical gears, have to lead it a bit. Mark the distributor housing with a sharpy if necessary in alignment with where the rotor is pointing when at TDC #1 on the compression stroke. Remember, the distributor cap is removed so it's tough to gauge. You'll see where it needs to drop in at though, I think this is right about where one of the spring clips is at. It can be a bit of a pain in the you know what. |
09-23-2021, 03:22 PM | #13 |
So, you like French?... wee-wee… haha
Let’s remember, the engine has run just fine for 7-8 years. Timing was perfect. I was able to loosen the bolt slightly last week, then tightened it a little, now I’m trying to loosen it again and now, no cigar.. I did order one of those Toolsource wrenches, so we’ll see. Crankster – thank you for the extended write up- and the most excellent idea of moving the plug wires over a hole. I think I prefer that to pulling the dist… and “Hoyle”? Didn’t he write Sherlock Holmes?? |
09-23-2021, 04:59 PM | #14 | |
09-23-2021, 07:46 PM | #15 |
I just adjusted the distributor in my 56 Bird (57 distributor). Just used a long extension, short 1/2 socket and appropriate ratchet, all 3/8 drive.
09-24-2021, 07:18 PM | #16 |
09-24-2021, 08:44 PM | #17 |
The distributor is a '55, with a pertronix module?
Assuming... the distributor housing was in a good position relative to the rest of the parts on top of the engine the last time it was working properly (and wasn't removed & reinstalled) Why is it now out of position??? IF... the breaker plate is somehow stuck in the fully advanced position that may be the source of the problem. Just a thought. |
09-24-2021, 10:10 PM | #18 |
Crankster, last time the dist was installed was when I overhauled the engine in late 2008. It has run fine since- no timing trouble,
dmsfrr, It is now out of positin because I installed a Pertronix electronic Igniter that replaces the points & condenser- forever. It moves the timing a little, so I am recalibrating it... But now, and this is the source of ALL my trouble, the dist holddown bolt is stuck. As in won't rotate with the available muscle I can put on it... However, where there is a will, there is a way. I am going to remove the accelerator/trans linkage mechanism in order to gain some clearance for a serious combo wrench, possibly even a cheater if necessary. All I know is, I am smarter than a stupid bolt- I WILL persevere,,, :-) |
09-24-2021, 11:49 PM | #19 |
If there's a bit too much corrosion on that hold-down bolt where it threads into the block it will snap off very easily. But you knew that.
09-25-2021, 06:06 AM | #20 | |
!!! AHA !!! What model PERTRONIX (I or II) did you purchase and PN if possible and exactly what did the instructions say as to ascertain correct IGN timing? Do you have a WORKSHOP MANUAL (ENGLISH EDITION - NO Fr.) for the car? Like mentioned, the plates maybe frozen are not moving correctly. |
