Old 06-01-2020, 10:05 PM   #1
wwirz
Default Gas Valve Installation - thread sealant recommended?
I am going to install a new gas valve on the underside of the gas tank. Can I use teflon tape on the NPT threads to the tank and little dab of gasket eliminator on the swedged end of the valve? Your recommendation please?
wwirz is offline   Reply With Quote
Old 06-01-2020, 10:11 PM   #2
SteveB31
SteveB31's Avatar
Default Re: Gas Valve Installation - thread sealant recommended?
No . No Teflon tape.
SteveB31 is offline   Reply With Quote
Old 06-01-2020, 10:36 PM   #3
Synchro909
Synchro909's Avatar
I use a dab of Permatex No 3.
Old 06-02-2020, 04:09 AM   #4
wwirz
I thought no tape. Just wanted to be sure. Permatex it is! THanks
Old 06-02-2020, 08:19 AM   #5
Badpuppy
Yellow teflon tape or pipe dope. It's a pipe thread. Permatex will make it tough the next time.
Old 06-02-2020, 10:14 AM   #6
Gary WA
Gary WA's Avatar
Indian Shellac- Napa
www.whidbeymodelaclub.com
Old 06-02-2020, 10:37 AM   #7
wmws
Yellow Teflon tape is fine as long as you get it on the treads only. Don't have it where it might get into the gas.
wmws is offline   Reply With Quote
Old 06-02-2020, 09:27 PM   #8
Big hammer
Teflon tape is a mechanics best friend....... for making money
If your the mechanic on your car, it's your worst enemy.
Liquid pipe sealer made for sealing gasoline !
get a bigger hammer tap done
Old 06-02-2020, 09:37 PM   #9
1crosscut
1crosscut's Avatar
Wouldn't it have to make contact with gas if it was needed to be used?
So far I've never had to use anything.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-02-2020, 10:31 PM   #10
Synchro909
Synchro909's Avatar
Permatex #3 doesn't harden. I've undone fitting where I used it years later and no problem.
Old 06-02-2020, 11:36 PM   #11
ursus
In another life, I assembled many VW bug engines and the two block halves were sealed with Permatex #3 and,upon disasembly, we used ethanol to wash away the stuff. My concern with Permatex #3 is that it is soluble in ethanol so would the 10% ethanol fuel that we are currently being sold potentially undermine at the sealing effect?
Old 06-03-2020, 07:22 AM   #12
wmws
Yellow Teflon tape is fine as long as it is on the threads and not up where it can get into the gas line. I have used it for many years on many applications with no problems.
Old 06-03-2020, 07:45 AM   #13
bkensinger
bkensinger's Avatar
Permatex Permashield is the ticket.
/Users/RobertKensinger/Desktop/thumbnail_IMG_0296.jpg
bkensinger is offline   Reply With Quote
Old 06-03-2020, 08:16 AM   #14
ABento
I haven't used permatex in years, I only remember the old stuff that got dead and hard, for gas I've been using Hilamar, spelling might be off on that, on the 32 to 34 trucks the hydro for the gas gauge is on the bottom of the gas tank, thats the only stuff that kept gas from leaking around the cap screws.
ABento is offline   Reply With Quote
Old 06-03-2020, 02:10 PM   #15
Ak Sourdough
Ak Sourdough's Avatar
Read the labels, any pipe thread compound that says it's good for gas or diesel (usually in a list of about 40 things), will work fine. I several varieties on my shelf, most are green in color but not all.
Ak Sourdough is offline   Reply With Quote
Old 06-04-2020, 04:12 AM   #16
midgetracer
midgetracer's Avatar
I use a product called Gasoila. It is a paste and used in the petroleum industry. It works very well and I have never had a leak using it. Just google gasoila.
midgetracer is offline   Reply With Quote
