Go Back   The Ford Barn > The Swap Meet > For Sale > Late V8
Old 05-02-2022, 06:21 PM   #1
rmengines
Default Ford 347 Stroker Engine kit
City: COLUMBIA CITY
State: Indiana
Price: In Ad
This is a 347 CI small block Ford stroker engine kit. This engine was ran for a short period of time before it was disassembled and the new block reconditioned. It comes with a pair of Flotec 200 cylinder heads, Scat cast crankshaft, Probe .030 over forged pistons mounted on H beam rods, Lunati hydraulic roller camshaft, Mellings HV oil pump and a completely machined block newly bored .030 over to match the pistons, new cam bearings and freeze plugs and the bottoms of the cylinders were notched to clear the rods. The crank was miced and polished and is Std rods and Std mains. The heads were disassembled inspected with the valves and seats ground with new valve seals and freeze plugs. 1.94" intakes and 1.54" exh valves. The pistons were miced and bead blasted. All these parts are in near new condition. Everything I have is shown in the pictures. $2650.00 Rick 260 438-1724
rmengines is offline   Reply With Quote
