04-04-2023, 08:50 PM | #1 |
1930 Model A Tie Rod Loose
Hi, just got a nice A; noticed the right-hand tie rod end has too much movement. I noticed there is no cotter pin in the end, and the end plug seems screwed in pretty far. The driver’s side has no looseness and it has a cotter pin.
I need to know how to inspect the joint: how to inspect the ball, mostly. I know the other parts are replaceable. |
04-04-2023, 10:47 PM | #2 |
Re: 1930 Model A Tie Rod Loose
Turn the screw plugs out and knock tie rod up past the balls. You should find 1 side has 2 cups and one side has 1 cup and screw end that surround the ball with 1 stout spring on each side. It is too dark out to see which side is the drivers side. The ball needs to be mostly spherical to give smooth steering.
04-05-2023, 07:20 AM | #3 |
OK thanks. I haven’t been able to turn the screw plug yet; I may have to buy the tool made for that. It’s not rusty at all. Otherwise the steering is very smooth.
04-05-2023, 07:46 AM | #4 |
On reassembly, how tight do you run in the end plug?
Till a little slop? Till no slop? 1-2 turns past no slop? Thanks Forum. You folks are THE BEST! |
04-05-2023, 09:53 AM | #5 |
The only reference that I've found that tells how to adjust the tie-rod, drag link ends is in my 1965 Ford Truck shop manual that says: "Tighten the threaded plug in the end of the socket until the spring is fully compressed (ball seat bottoms on spring seat). Then back off the plug approximately 1 turn to the point where the slot in the plug lines up with the cotter pin holes in the drag link. Install a new cotter pin through the end of the drag link to lock the plug."
Not sure if this apples to Model As or not.
04-05-2023, 10:07 AM | #6 |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
04-05-2023, 10:10 AM | #7 | |
Les Andrews Red Book sez;
Are you thinking on the drag link? Last edited by Y-Blockhead; 04-07-2023 at 10:47 AM. |
04-05-2023, 10:23 AM | #8 |
Here's how the tie rod and drag link should be assembled:
04-05-2023, 11:41 AM | #9 |
I was just looking at a catalog photo of the parts kit to try and jog my memory, you are correct since the kit is for either. He may be missing a part or has a broken/wrong spring on the loose side.
04-07-2023, 07:11 AM | #10 |
If the spring is 1" when non compressed. Fully compressed would still be 1/2", since the spring itself has coils with cumulative length, then 25% compressed would be about 7/8". The plug is 16 tpi I think, so tightening 2 turns after all slop is removed would be about 1/8". Does that make any sense?
Jerry |
04-07-2023, 09:50 AM | #11 | |
What I've found in practice is that after a certain point it becomes so difficult to screw in the plug that you just say "good enough" and put in the cotter pin. JayJay
