11-18-2021, 09:16 AM | #41 | |
Re: newly rebuilt and a knock
Looks like he's already done that and the builder is telling him that the engine was fine when it left, making it the owner's problem. |
11-18-2021, 09:17 AM | #42 |
good idea it is a 2500 mile trip one way cheaper to just buy another motor
11-18-2021, 09:54 AM | #43 |
11-18-2021, 10:09 AM | #44 |
not giving out the name until i find out if it was something that was done wrong.
11-18-2021, 10:35 AM | #45 |
Check your "Private Messages" in the top right corner of this web page.
Marshall |
11-18-2021, 10:38 AM | #46 |
I'm not finding fault with what you have done, your unwillingness to disclose the builder until you've worked through this says volumes about your integrity.
11-18-2021, 10:46 AM | #47 |
11-18-2021, 12:03 PM | #48 |
Here is another idea: Post a video of the knock on the Barn. Others have done that and their knock was able to be analyzed.
11-18-2021, 12:22 PM | #49 |
I once had a bad knock and it turned out to be caused by the fan belt. An easy fix!
11-18-2021, 05:32 PM | #50 |
The distributor drive shaft was stuck in the drive end and the top end . This should not be a tight fit at both ends it acts a universal joint so is a semi loose fit . Repro shafts sometimes have to be dressed for the fit to be correct just a connection not a rigid join . When you pulled the distributor up as the shaft was jammed at both ends you were compressing the spring which holds the oilpump/distributor drive gear down in place . It could be you lifted it up so far that when you pushed it back in you engaged the drive gear out by a tooth on the camshaft . This would affect the timing the engine will run but it would not be happy maybe causing the knock . An easy fix use the timing pin for TDC and reset the cam as per the good books . I would pull the shaft out with needle nose pliers and dress each end for the correct fit you should not need to press it in position . When you pull the distributor out the shaft stays in the block .
John in Suffolk County England . |
11-18-2021, 07:23 PM | #51 |
I'm changing the front bearing on my generator, it was/is worn out and was causing some knocking.
Update: Well it wasn't that bearing...damn it
Keith Shawnee OK '31 SW 160-B Last edited by burner31; 11-27-2021 at 09:42 AM. |
11-18-2021, 08:22 PM | #52 | |
11-19-2021, 08:25 PM | #53 |
If you have to push down on the distributor it sounds like the spring that holds the dist./oil pump drive gear up has popped out of position. That spring kind of wants sits at a cockeyed angle anyway and is easily installed so it can kick out. Remove the valve (side) cover and see if it's out of position. Also check to make sure it was installed correctly. It goes on top of the drive gear. I would not run the engine until you check this and fix it. If the drive gear is pushed up the oil pump probably is not operating and that's not good at all.
11-26-2021, 08:46 PM | #54 |
thank you all for your help the problem has been solved it was a timing knock. the lower distributor shaft was stuck in the cam gear coupler and also stuck into the bottom of the upper distributor shaft. got everything out of the motor clearanced the shaft so it was a slip fit put everything back together and now it is all set
11-26-2021, 09:32 PM | #55 |
Glad you fixed it!
11-26-2021, 09:58 PM | #56 |
Did you have to re time the ignition?
11-26-2021, 09:59 PM | #57 |
yes because i had moved it
11-27-2021, 07:24 PM | #58 |
Good news nothing major .
Dennis in Kelsey ca |
