Old 11-21-2010, 03:28 PM   #1
dan
dan's Avatar
Default Cool vintage engine illustration
From a site my wife frequents:
http://www.etsy.com/listing/60483480...-works-vintage
dan is offline   Reply With Quote
Old 11-21-2010, 04:28 PM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Cool vintage engine illustration
Those "valve caps" would allow you to change valves without removing the head.
Old 11-21-2010, 05:54 PM   #3
Harold frm Sebastopol
Harold frm Sebastopol's Avatar
Location: Sebastopol, CA (Sonoma Co.-Home of Sonoma Model A's)...Come see Snoopy, Luther Burbank, Taste wine/
They say 27 Model A
I guess they are saying "early 28"?
Harold frm Sebastopol is offline   Reply With Quote
Old 11-21-2010, 06:07 PM   #4
Doug in NJ
Doug in NJ's Avatar
Is that even a Ford engine? It looks a lot older than 1927...
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 11-21-2010, 06:32 PM   #5
ddweave
ddweave's Avatar
If it's a Ford engine at all, it predates the Model T. Note that the engine is headless.
I don't know what it is.
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 11-21-2010, 10:07 PM   #6
B0B
That looks like the Original first Model A engine 1903 -1906 ? i am guessing about the date...Remember Ford made the model A way back in the beginning then decided to make the Model A again later in 1927 ... REB0b in michigan
B0B is offline   Reply With Quote
Old 11-22-2010, 12:25 AM   #7
40 Deluxe
It's not the 1903 Model 'A'. That one was a two cylinder horizontally opposed layout. Nowhere on these drawings does it say it's a Ford Model A. The seller in all ignorance is calling it an 'A'.
Old 11-22-2010, 12:31 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Could be one of the other models up to the T if it's a ford at all.
The early fords
Old 11-22-2010, 12:52 AM   #9
MrTube
MrTube's Avatar
I don't understand how the valves and sparkplug are connected to the cylinder? It looks like its blocked off with a water jacket in between.
MrTube is offline   Reply With Quote
Old 11-22-2010, 01:45 AM   #10
dave in australia
I don't think it's a straight sectional cut. I think they've cut down through the valve chamber for no1 cylinder, then dog legged to the cylinder of no2 cylinder to give you a view of both areas.
dave in australia is offline   Reply With Quote
Old 11-22-2010, 02:10 AM   #11
mot
Registered User
mot's Avatar
ive seen Buick engines that were similar to this one
there was no separate head
mot is offline   Reply With Quote
