10-08-2015, 06:46 PM | #1 |
I'm thinking it's time for a new head gasket..
Fired the old girl up today and noticed some seepage around the head. This could explain the water in the oil that I noticed on the last oil change. Compression readings today were all around 53 to 58. Think I should do the high compression head also. What is the best head to go with? I've read a lot here but can't decide on the correct head. Any input is greatly appreciated.
Jim P. central Ohio 1930 Tudor Sedan 15 grandchildren and 2 great grandchildren and loving it!! |
10-08-2015, 06:51 PM | #2 |
Re: I'm thinking it's time for a new head gasket..
I have rarely seen an A head that didn't seep. Re-Tourque and see how that goes.
Oklahoma City Model A Restorers Group. |
10-08-2015, 07:27 PM | #3 |
That is nothing. Agree with Tincup retorque. How many miles on it?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-08-2015, 07:32 PM | #4 |
Don't no mileage. Car set for 15 yrs. after restoration was started. Runs good but I get some moisture in the oil.
10-08-2015, 07:34 PM | #5 |
Where abouts are you in Central Ohio Wareagle
1930 Deluxe Coupe "Sister" |
10-08-2015, 07:46 PM | #6 |
10-09-2015, 01:40 AM | #7 |
Short engine runs will leave moisture in the oil.
If you go for a high compression head, my choice would be the Snyder's 5.5 with a copper gasket and Copper Coat sprayed on both sides. |
10-09-2015, 05:44 AM | #8 | |
Make sure you get the new head surfaced as there are reports that they come through twisted. |
10-09-2015, 08:05 AM | #9 |
Thanks guys. Think I'll call Snyder's today and order one. Can any machine shop check it for flatness?
10-09-2015, 12:38 PM | #10 |
If any machine shop can't, RUN!
10-09-2015, 01:04 PM | #11 |
For a car that has been stored a long time, I first Torque the head & add a jar of the plain old original BARS-LEAKS.
Bill W.
10-09-2015, 01:08 PM | #12 |
10-09-2015, 01:40 PM | #13 | |
My engine has the same leakage as yours, but my car sat for 56 years, afraid to re-torque right now out of fear of breaking a bolt, it runs good so I decided to keep going until I take it off the road for the winter in a month or so, depending on weather. Put about 350 miles on it since I got her running in Febuary, no water in the oil, which I have changed three times since, over kill? maybe, but after 56 years I run it for a 100 change, repeat. Next season will be a different story, but for now thats my method for a clean engine.
10-09-2015, 02:11 PM | #14 |
At 55 ft lbs you will not break a bolt. Back off and re-torque 1 at a time.
10-09-2015, 03:47 PM | #15 |
Thanks guys. I ordered the new head from Snyder's. I have tried to re-torque the head before when I drained the oil and found water. I thought if I had to replace the head gasket, I might as well replace the head at the same time. I will take it to a guy here that does race engines and have him check flatness.
10-09-2015, 04:02 PM | #16 | |
10-09-2015, 04:07 PM | #17 | |
You will certainly like the added performance with the Snyder head I love mine.
10-09-2015, 04:13 PM | #18 |
10-09-2015, 05:43 PM | #19 | |
Paranoid Bill W.
10-09-2015, 06:17 PM | #20 |
