Old 03-22-2014, 06:38 PM   #1
Duffy1
Default Sta-Bil 360
Claims to prevent corrosion in the gas tank and fuel lines. 1 oz for every 5 gallons of gasoline. Do you think it will cause engine problems ? Appreciate your comments.
Duffy1 is offline   Reply With Quote
Old 03-22-2014, 07:22 PM   #2
Mitch//pa
Default Re: Sta-Bil 360
this new product was at this years sema show. i am not one for additives or snake oil, i like the concept of what it does and would consider using it ..here is a link to it.
http://www.sta-bil360.com
Old 03-22-2014, 07:27 PM   #3
glenn in camino
glenn in camino's Avatar
I put it in my house generator so it will run next time the power goes off.
glenn in camino is offline   Reply With Quote
Old 03-22-2014, 07:33 PM   #4
Mitch//pa
its not your traditional sta-bil that you been using
read the site
Old 03-22-2014, 07:59 PM   #5
Ross/Kzoo
Ross/Kzoo's Avatar
What's really funny/sad is that the product cost $20 to treat 60 gallons. The ethanol was supposed to be environmentally friendly but look at all the peripheral costs involved to use this green friendly ethanol.
Ross/Kzoo is offline   Reply With Quote
Old 03-23-2014, 09:52 AM   #6
Uncle Bob
Uncle Bob's Avatar
This was also discussed on the V8 side awhile back: https://fordbarn.com/forum/showthread.php?t=131768
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 03-23-2014, 10:10 AM   #7
DrinkMan
DrinkMan's Avatar
I'm willing to try it. I use the regular Sta-Bil with every tank of gas on my Opel with Weber. Before I used it, every 500-1000 miles, the performance would drop due to a "varnishing" effect that clogged one of the idle jets from the Ethanol. Now, with Sta-Bil, I don't have the problem anymore. Since it appears to cost more than the regular Sta-Bil, perhaps I can alternate between the two products to save a penny or two.
Life is too short to drive boring cars or drink boring beers. Just don't do them both at the same time.
A diverse fleet - nothing boring:
1928 Ford Tudor
1969 Alfa Romeo Spider Veloce (Duetto)
1973 Opel GT
1973 Triumph TR6
1979 Triumph Spitfire w/GT6+ engine: Spit6
2005 Lotus Elise
DrinkMan is offline   Reply With Quote
Old 03-23-2014, 12:11 PM   #8
Duffy1
Thanks for the feed back . So as far as anyone knows this product may or may not perform as advertised but WILL NOT HARM THE ENGINE .
Old 03-23-2014, 12:21 PM   #9
Jim/GA
Jim/GA's Avatar
I have noticed for many years now -- ever since ethanol in gasoline has become common -- on both my old cars and on my modern cars, a white chalky residue has formed on the inside of my metal gas caps. I had not seen that before, so I assumed it was from the ethanol. If it is on the metal cap, it is probably on the inside of the metal tank above the liquid level.
It sounds like this "corrosion" (if that's what the white chalky stuff is) is what this new fuel treatment is designed to stop.
Probably worth a try in a controlled experiment to see if this additive stops this.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 03-23-2014, 01:59 PM   #10
Patrick L.
Patrick L.'s Avatar
Ethanol laden fuel is anything but environmentally friendly.
I'm not a big fan of Sta-bil. I've seen it separate in the bottle and not dissolve when mixed with the fuel. Don't know anything about this new product, but, stopping rust or corrosion within the tank has to be a good thing.
As far as fuel storage, ethanol doesn't store for chit and IS bad for small engines. When storing fuel I use non-ethanol with a fuel treatment [ I like Sea-Foam, it works].
When it was too hard to find non ethanol stuff, for years I used 100LL.
Old 03-23-2014, 02:25 PM   #11
hardtimes
hardtimes's Avatar
Hey Patrick L,
Boy , I guess that we have at least ONE good thing left on the left coast..i.e.- no ethanol..whoohoo,eh ! At least none that I have run into.
But, I still use the regular Sta-bil concoction ...in everything that is stored away for any amount of time. Experimentation/experience is that it works for stored fuel, IMO. Haven't tried the new version, and probably won't as that price , to me, is exorbitant
What 'iritates' me abut ethanol...is that WE subsidize the making of it !
hardtimes is offline   Reply With Quote
