10-09-2015, 07:15 PM | #21 | |
Re: I'm thinking it's time for a new head gasket..
All I can say to the OP is "Take Care" and by the way, I think you are doing the right thing with the 5.5:1 head. I have 3 of them and wouldn't go any other way.
10-09-2015, 07:54 PM | #22 |
here is the recent thread about the new snyders 5.5 heads being twisted.....
https://fordbarn.com/forum/showthread.php?t=79701 |
10-10-2015, 08:03 PM | #23 |
Got the new head in today. Took it over to my friend that owns the local machine shop and had him check it out. Head was straight and level with no twists are warpage. He said it was good to go. After removing the old head, I noticed a set of numbers stamped on the block between the 2nd and 3rd cylinder on the driver's side. Does any one know what these numbers mean?
Jim P. central Ohio 1930 Tudor Sedan 15 grandchildren and 2 great grandchildren and loving it!! |
10-11-2015, 04:19 PM | #24 |
Head seepage common,water in the oil, condensation,install a thermostat to raise temperature
10-11-2015, 04:52 PM | #25 |
Remember, just because someone titles himself a "RACE MECHANIC" doesn't necessarily mean that he's an "EXPURT" on EVERYTHING!!!
I sometimes call myself a DOCTOR, may I perform your next BRAIN SURGERY? I have REASONABLE PRICES & use the accepted "FLAT RATE BOOK" & employ a cute seamstress, that does DECORATIVE STITCHING!! Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 10-11-2015 at 07:44 PM. |
10-11-2015, 06:49 PM | #26 |
Paul in CT |
10-11-2015, 08:28 PM | #27 |
The numbers were stamped between the 2nd and 3rd hole on the outer edge. The numbers were 1824. No other markings. Just curious as to what these mean.
I know just because he builds race motors doesn't make him a mechanic but his Dad did run nascar back in the day and he has built engines and designed the cams for some ARCA and Xfinity race engines. So I hope he knows what heads should ok to run.
10-12-2015, 08:19 AM | #28 | |
It can wait
