02-27-2023, 06:50 PM | #1 |
FOMOCO Tool I.D. #T53P-3355 Needed!
Got this Fomoco tool with something else very cool and hope someone can provide some information as to it's use and era it came from. Series of collars and main bolt?, might be missing a collar as well. Thanks, GaryU.
02-27-2023, 07:06 PM | #2 |
Re: FOMOCO Tool I.D. #T53P-3355 Needed!
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 02-28-2023 at 02:40 PM. |
02-27-2023, 07:06 PM | #3 |
Upper control arm bushings? —— after the flathead era
02-27-2023, 07:08 PM | #4 |
02-27-2023, 08:05 PM | #5 |
T53 indicates a Ford special tool issued in 1953. The 3355 I would think is front suspension. If someone has a Manzel tool catalog they might be able to tell you more.
02-28-2023, 11:49 AM | #6 |
T65P-3000-B-2 or C-2 (Front Alignment Spacer Tool) (Includes 2 of this tool) T65P-3000-B-1 or C-1 (Rear Alignment Spacer Tool) (Includes 2 of this tool) T65P-3000-A (Caster and Camber Adjusting Tool) T74P-3000-A2 / -A4 / -A5 / -A6 (Front and Rear Caster and Camber Adjusting Tools) T65P-3576-A2 (Steering Sector Shaft Bushing Remover and Replacer Tool) T61B-3553-A (Power Steering Control Valve Spool - Spanner Wrench) T61B-3553-B (Power Steering Valve Spool Centering - Worm Bearing Nut - Lock Nut Wrench) T58T-7140-A (Manual Transmission Reverse Idler Shaft Remover) T53P-3355-B (Idler Arm - Steering Arm Bushing Press Tool) T61P-3355-B (Idler Arm - Steering Arm Bushing Press Tool) T68E-6038-A (Engine Service Mount - Support Plate) T64T-7550-A (Clutch Disc Pilot Tool) T68P-6135-A2 (429-460 Piston Pin Remover and Replacer Press Tool) T64T-6306-A (Crankshaft Damper Replacer Tool, For 170-200-289-302-351-390-427-428 Engine) T64T-6306-A3 (Crankshaft Damper Replacer, Unknown Engine) |
02-28-2023, 05:58 PM | #7 |
Saw that this morning right before I left for work. Here's a link to that auction. https://www.ebay.com/itm/15520729969...3ABFBM5OuN_dJh
