Old 09-29-2021, 06:47 PM   #1
Blindhuckster
Blindhuckster's Avatar
Default Fuel Pump leak after Rebuild
I just rebuilt my fuel pump due to an issue with diaphragm deterioration. It was flaking off and plugged one of the jets in the carb. I used a Napco rebuild kit. Since rebuild, the pump has leaked. The best I can tell, it leaks at the diaphragm, not the fuel line. If I tighten the screws it will stop, but after several days the leak returns and I have to retighten the screws. I am going to remove the screws and add some loctite 577 to the threads. Pump never leaked before. Just wondered if anyone had this issue in the past. Luckily I have access to non-ethonal gas locally and that's all I run. Just wondered if I'm missing something here.
Blindhuckster is offline   Reply With Quote
Old 09-29-2021, 06:59 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: Fuel Pump leak after Rebuild
Looking at your pictures, I can’t tell if there are lock washers under the screw heads. I’ve used them on my pump.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 09-29-2021, 07:36 PM   #3
Charlie ny
Those 10-32 cap screws are good for one use....minimal head thickness. Many
vintage pumps used larger diameter lock washers or 10-32 phil head screws with
larger diameter heads. Either style spreads the force over a bigger area. I save these fasteners when I find them. I would try disassembling the pump and touching the gasket
faces on a disc sanding machine to eliminate the distortion that inevitably happens
with over tightening.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 09-29-2021, 08:44 PM   #4
Blindhuckster
Thanks Gentlemen, Yes there are lock washers under the screws. This pump is a Bob Drake reproduction that was on the car when I purchased it. I will disassemble and sand the gasket surfaces. Thanks Charlie.
Old 09-29-2021, 09:04 PM   #5
cas3
With pot metal stuff like a fuel pump housing I always true them up with fine sandpaper on a flat surface like a table saw etc. Similar to what charlie said above. you would be surprised how much they are warped. Do the mounting flange too
Old 09-29-2021, 10:25 PM   #6
19Fordy
19Fordy's Avatar
Use two gaskets.
