Old 03-22-2022, 12:30 AM   #1
GaryU.
GaryU.'s Avatar
Default An odd duck? Straight six "hogshead to "39 style open drive transmission.
This was on a 1948 F-1 pickup that seller had on C-list. He had listed the engine/trans. combo for sale as he is doing a Restomod project with the pickup. I offered to buy the open drive transmission only and was surprised he was willing to sell, turns out the engine was already sold to a guy for a Ford tractor project. He didn't need the adapter so I have it along with the transmission and driveshaft for the slip yoke. Just listed the adapter in the the swap section and was curious if these were readily available? Straight six to 78 series transmission case adapter, pressed steel not cast. Disregard the pressure plate in photo, was for transport, have the clutch as well. Thanks
GaryU. is offline   Reply With Quote
Old 03-22-2022, 12:55 AM   #2
cas3
Default Re: An odd duck? Straight six "hogshead to "39 style open drive transmission.
Standard thing for the 6's, its about 3/4" deeper than a v/8, and of coarse the bolt pattern on the engine side is different
Old 03-22-2022, 06:05 AM   #3
nickthebandit
That is a stamped steel bellhousing, not a "hogs head".
nickthebandit is offline   Reply With Quote
Old 03-22-2022, 08:11 AM   #4
51504bat
51504bat's Avatar
Starter plate with it?
Old 03-22-2022, 05:13 PM   #5
51504bat
51504bat's Avatar
Here's a complete set up on C/L:
https://losangeles.craigslist.org/sf...457120783.html
Old 03-22-2022, 05:31 PM   #6
GaryU.
GaryU.'s Avatar
Thanks for posting that ad, wish they showed the other side. Also mine is a top loader not side, I don't have a starter plate, were they a separate item? The pickup mine came from must have lived a charmed life, gears inside are almost mint as well as the slot on the shifter. The cab and other parts were not rotted at all, box floor had rust but no holes.Lots of original red paint on engine in ad as well as the "bell housing", had to look up paint colors for that era, think it's correct? Safety wire still on bolts on rear bearing retainer, rear trans. mount.
Old 03-22-2022, 09:19 PM   #7
51504bat
51504bat's Avatar
file:///C:/Users/User/Desktop/Car%20Info/Parts%20Sources/bellhousing-1.pdf
Look at photo #15
