Old 08-16-2017, 05:26 PM   #1
Dick Deegan
Dick Deegan's Avatar
Default Manifold Broken Stud
I have a broken manifold stud at #3 cylinder. I went to adjust the torque on the studs yesterday for the first time since I have owned this car and as soon as I started to apply some torque the stud came away. The stud is not proud to the engine block, but is into the block by about 1/16".
I have a set of extractors. I have tried to drill a hole with a 5/32" colbalt drill bit, but the drill won't make even a dent in the broken stud. I have also tried to move the stud with a small chisel, but top no avail.
I have oxy acetylene, but am very reluctant to use it.
Any suggestions will be appreciated.
Dick Deegan is offline   Reply With Quote
Old 08-16-2017, 05:49 PM   #2
Art Newland
Art Newland's Avatar
Default Re: Manifold Broken Stud
https://www.youtube.com/watch?v=1bZyw3OSIgk
Art Newland is offline   Reply With Quote
Old 08-16-2017, 08:39 PM   #3
Big hammer
Find someone with a mig or tig welder, have them weld a washer and nut to the stud, it works very well. DONT drill and easy break!
get a bigger hammer tap done
Old 08-16-2017, 09:28 PM   #4
Drive Shaft Dave
Big Hammer is right use the weld a washer, then a nut It will come out, it may take a few tries to do it but it will come out.
Drive Shaft Dave is offline   Reply With Quote
Old 08-16-2017, 10:33 PM   #5
SeaSlugs
SeaSlugs's Avatar
yup - done that trick a few times. Ive had success both ways of welding it and letting it natually cool down and done welding let it not be orange then shock cooling it with some penetrant oil or bucket of water.
When you go to remove the nut rock it back and forth with a normal wrench even if its not moving all it takes is a fraction of a micrometer to start turning a hair - then keep soaking in penetrating oil and keep rocking it back and forth not applying alot of torque. as you back it out and it starts getting tight soak some more and run it back in and keep bouncing it out.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
