05-25-2011, 10:03 AM | #1 |
Main Bearing Oil Groove Opinions
I bought a rebabitted block at an auction last weekend. It was done by a local guy with a reputation of doing good work.This was one engine he did not finish before he passed away. He used the molds with the round groove as opposed to the spiral KRW oil groove cutter. Since I have the KRW cutter and could cut the groove would it be a good idea to go ahead and cut the spiral groove or am I asking for trouble in doing this? Probably not neccessary, just curious as to opinions from experienced engine builders. Thanks Rod
05-25-2011, 10:25 AM | #2 |
Re: Main Bearing Oil Groove Opinions
I would just use the grooves that are in it. Putting in others reduces the amount of bearing area supporting the crank.
05-25-2011, 10:35 AM | #3 |
Thanks Jim, that was most of my reasoning for not as I did not want to weaken the bearing. I do prefer the spiral groove as I feel it oils the mains better, but many engines out there ar living fine with the single groove. Rod
05-25-2011, 10:40 AM | #4 |
for some reason on both my A's. the rear mains do not have an grooves.
05-25-2011, 10:47 AM | #5 |
Have to disagree with Jim on this one. The Model A has plenty of bearing surface for its power, the Wilson grooves are narrow, and I think the additional lubrication would be worth it. However, babbitt thickness would be a consideration before any more grooving. More important is whether there are beveled reliefs at the parting lines and thrust surfaces. They are easy to file to about 1/4 inch from each bearing end, and you really need them especially if you stay with the circumferential groove. .
05-25-2011, 10:49 AM | #6 |
05-25-2011, 10:55 AM | #7 |
Since the load is on the bottom (cap), you can do the block side.
Dudley |
05-25-2011, 05:49 PM | #8 |
Reliefs on the part lines on a bearing are called oil wells, and that is exactly the job they are there for. Circle grooves in bearings should be used for oill pressure "ONLY". The oil well, in combination with the spiral groove is best used on the splash bearing. You would not loose bearing surface, as the added grooves DO NOT, take away from bearing surface, but add to it. The OIL, is your bearing surface, not the lack of a oil grove in that area. A bearing will NOT FAIL because it got to much oil, it fails because it was shorted of oil. "OIL MOLECULE", is always your bearing surface, not the area of bearing that the shaft is not supposed to ever touch. Herm
05-25-2011, 09:33 PM | #9 | |
05-26-2011, 12:14 AM | #10 | |
05-26-2011, 10:40 AM | #11 |
Well said Herm & James!
04-25-2021, 01:24 PM | #12 |
I know this is an old thread but nevertheless ...
Herm and James seem to agree on an oil film carrying the load of the crankshaft. I do too ! But, pour some oil on your counter and stack some bricks. Will they float ? You need the natural oil pressure from the crankshaft turning around (hydrodynamics). Now, why would you interrupt the oil pressure by adding an oil groove right across the pressure bulb ? In doing this you create a pressure leak ! Henk
You don’t own a Model A ... it owns you ! |
