08-12-2018, 04:16 AM | #1 |
Finding .045 Piston Rings 8BA
Hi Guys, Been a member for a while but this is my first post. I live down under in Australia and have a fairly complete 8BA here that I bought about 6 months ago for a project. This is my first Flathead V8 I've ever owned so I'm in unfamiliar territory with these engines though I am an " old school " car mechanic from years back, in the early to late 1980's when I was last on the tools there just weren't any flatheads around in those days so I've never worked on them. To the subject, This 8BA I have here came out of an old farm truck. It's not seized and the heads are off it. The bores all look good and there is no ring ridge at all in any of the cylinders. I have an inside micrometer/bore gauge but haven't as yet done any measurements with it but my instincts and experience tell me this is a re-ringable engine with a clean up and freshen up. At this stage ( without pulling it apart just yet ) I would like to re-ring it. However, At some stage in it's life it was fully rebuilt by Ford Australia and has a stainless steel plaque attached to the engine block near the distributor stating the work that they had done. It was rebuilt to take .045 oversize pistons, .010 under on the crank pins and mains. Back in the day .045 pistons were probably ? easy to find, however fast forward 40/50/60 odd years to now and this oversize is now not considered a common overbore.We seem to go in units of 10 now for oversize pistons, not in units of 5. And my problem is I can't seem to find .045 rings for an 8BA anywhere? I am planning on a pulldown,inspection and re-ring in coming months with view to get it running in my garage on a stand and I'm OK with reboring it to .060 if required but if it's an engine with life left in it as is, with a re-ring ,then I'd rather go that way if I can with a rebore as a standby option. Can anyone advise if they know where I might be able to find .045 rings at all ? Cheers from Australia. ........ |
08-12-2018, 04:36 AM | #2 |
Re: Finding .045 Piston Rings 8BA
a few years ago a guy in geelong had lots of old stock ford parts I got a set of 45 over rings from him but cant remember his name
08-12-2018, 05:05 AM | #3 |
In the past I have brought them from Bernie at Auto Surplus. The phone number is
9873 3566 and they are at 35 Rooks Road Mitcham 3132 Victoria Redgards,Gary |
08-12-2018, 05:50 AM | #4 |
08-12-2018, 05:54 AM | #5 | |
.... Thanks Gary, I'll give Auto Surplus a call tomorrow morning, thanks for the tip. By the way, do you know where I might find an Australian car 8BA starter mount plate at all ( left hand bolted starter ). I've just bought a left handed starter cast iron bellhousing but the seller did'nt have the starter plate to match. Thanks. ..... |
08-12-2018, 06:34 AM | #6 |
Here from the Barn .
"I can't cry as long as I know the Lord has risen " |
08-12-2018, 07:17 AM | #7 |
I have heard of guys putting .010 over rings in worn bores so I'm guessing if all else fails .050 and setting the end gaps will probably work for you. Anyone here feel free to correct me with experience.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
08-12-2018, 10:10 AM | #8 |
If you can find .050 rings, then just file-fit them back to whatever size the bores need. I usually try to buy rings that are .005 over the bore size for most modern performance rebuilds - then hand fit them. On modern engines they are usually marked for the resulting bore size -- like .030, but then "file fit" is added - to denote that they are oversize and must be filed to fit the actual bores of the engine.
08-12-2018, 10:19 AM | #9 |
Just send an e mail to Hastings and the tech people will be able to tell you if they have any rings that will suit your needs. You will have to give them an accurate finished bore size.
R |
08-12-2018, 12:31 PM | #10 |
Barnfind08 on here has lots of old stuff and NOS stuff too. he may be able to help as well
08-12-2018, 12:52 PM | #11 | |
08-12-2018, 12:53 PM | #12 |
How common was .045 in the 8BA ?
I have .045 canada made in 3 1/16 and 3 3/16 for the earlier engines but not 8BA. Think we got army suplus that was .045...any reason why .045 was choosen ? |
08-12-2018, 01:07 PM | #13 |
Dunno, but they probably just used to go .015", .030", .045", .060" when rebuilding. Military rebuilding on a schedule, rather than waiting until worn out.
I have a couple of sets of .045" 99A pistons. The French military motors also use +.045", actually marked 1.14mm. Mart. |
08-13-2018, 03:00 AM | #14 |
G'day Van,
We have just moved house and I have stuff scattered to the four points of the compass BUT I think I may have what you are looking for. I have a couple of days off later in the week so I can go looking. Regards, Gary |
08-13-2018, 05:21 PM | #15 | |
..... .. Ok, thanks Gary, that would be great if you could find a starter mount plate for me. The one I need is for the Australian cast iron bellhousing with the starter in the left hand passenger position. My bellhousing should arrive in the mail sometime this week. If I can find out how to post photos up here I'll post a pic when it arrives. Thanks again. ....... .. |
