Old 10-13-2016, 06:08 PM   #1
ckh
Default Advice needed on flanged full floating bearings
From what I can tell these bearings were offered in these different types:
Nickel cadmium, Tin base babbitt, Lead base babbitt, and copper lead base.
Is there a preference as to which type to use in a stock 36 engine or does it
even matter?
Thanks
ckh is offline   Reply With Quote
Old 10-13-2016, 09:29 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Advice needed on flanged full floating bearings
It might matter if you are an engineer, racer, or just generally anal. I would use any I could find.
Old 10-15-2016, 09:17 AM   #3
jetmek
I think the copper and nickel base were for heavy duty applications . youll be lucky to find anything in a size you need
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Thread Tools
Display Modes
