06-13-2015, 08:46 AM | #1 |
Dual carbs on an Offenhauser manifold
I plan to put an Offenhauser regular dual on an EAB 53 V8. Which carbs would you use, Holley 94s or Stromberg 97s ?
06-13-2015, 08:59 AM | #2 |
Re: Dual carbs on an Offenhauser manifold
My personnel choice, Holley 94's
06-13-2015, 09:26 AM | #3 |
that's what I have
06-13-2015, 09:40 AM | #4 |
ole,
For what it is worth I lean to the Strombergs because everything is mechanical. The vacuum power circuit on 94's can be challenging......not impossible for sure but pretty much not an issue with Strombergs. I will STRESS if you go with 94's be sure they are 94's not the bigger 1" or 1 1/16" variety and get your kits ,especially power valves, from DAYTONA PARTS in Florida. These are my opinions only and I certainly respect everyones opinion. Charlie ny |
06-13-2015, 09:59 AM | #5 |
I went with 94's and it worked well.
06-13-2015, 10:34 AM | #6 |
06-13-2015, 10:41 AM | #7 |
sent you a pm.
06-13-2015, 12:59 PM | #8 |
If you have a stock distributor, the strombergs will be a challenge Rich
06-13-2015, 01:56 PM | #9 | |
This link gives some good info on that. |
06-13-2015, 03:15 PM | #10 | |
I know it's been done, and some folk claim it works, it just can't work properly, plain and simple. Maybe with enough time, patience, distributor machine that can add vacuum advance or a good dynomometer and operator and a huge selection of springs, you may get somewhere, somewhen. Dual carbs on a loadamatic? Just not worth the agro and disappointment. Fit and ignition with centrifugal and preferably vacuum advance, correctly calibrated, you won't be sorry. Martin. |
06-13-2015, 03:32 PM | #11 |
Martin is right, dual carbs on an 8BA, just don't work right with the stock distributor. In fact the stock dist doesn't work very well with the right carb most of the time.
06-13-2015, 04:25 PM | #12 | |
Just my opinion.,...jack
Proud FNG We fixem cars. Heap Good! |
06-13-2015, 08:52 PM | #13 |
Or Charlie, NY.
