04-14-2015, 10:57 AM | #1 |
1952-53 rear end gears
I was wondering what the rear end ratios were used with overdrive and non overdrive cars? Also what about Fordomatics.
04-14-2015, 12:01 PM | #2 |
Re: 1952-53 rear end gears
i believe: OD is 4.11 nonOD is 3.73 auto should be 3.32 i have a 53 with OD and it was 4.11 and have sonce changed to a 8" with 3.50 and another car with an auto i think is 3.32 not much power in the car with the auto but the motor is quite tired.. station wagons had a different style differental and i believe they were 3.55
04-14-2015, 01:58 PM | #3 |
If I was to put AOD transmission in my 53 with 3 speed overdrive, would I have to change the gears in the rear end?
04-14-2015, 02:36 PM | #4 |
For 1953 they have two options for each transmission choice. 3.90or 4.10 for standard trans., overdrive lists 4.10,3.90 and 3.54. Merco-matic 3.3 or optional 3.54.
https://www.youtube.com/user/roosty6/videos |
