Old 03-06-2021, 08:52 PM   #1
Racur96
Racur96's Avatar
Default 29 ccpu frame welting & body blocks
Hi , I’ve read some post & the frame welting goes on the frame then the splash aprons. The front body block under cowl the rubber shins go between the bottom of cab & on top of the apron correct ? On The center & rear cab blocks are the rubber shins nailed to the top or bottom of the wood mounting blocks , if they went on top I assume the bottom would rub against splash apron or do you put a shim on top & bottom ? Or a shims on one side & welting or something on the other ? Thanks
Racur96 is offline   Reply With Quote
Old 03-06-2021, 10:38 PM   #2
Brentwood Bob
Default Re: 29 ccpu frame welting & body blocks
https://www.fordbarn.com/forum/showt...ocks+placement
Do a thread search if this doesn't answer you questions good enough.
Brentwood Bob is offline   Reply With Quote
Old 03-06-2021, 11:59 PM   #3
Racur96
Racur96's Avatar
I’ve read that post & others I’ve searched but didn’t see anything yes or no about a pad or felt on topside it rear & center body blocks between block & body? It may not hurt anything I just assumed there might be some type of noise if something wasn’t there.
Old 03-07-2021, 12:16 AM   #4
Steve Plucker
Here is some data that might help you along in some areas:
http://www.plucks329s.org/pdf/studie...EAKARTICLE.pdf
Pluck
Old 03-07-2021, 01:50 AM   #5
Brentwood Bob
Per les Andrews red book, nothing between wood and body.
