Old 12-15-2021, 10:37 AM   #1
BillCNC
BillCNC's Avatar
Red face Your biggest Model-A mistake of the year?
Hey All,
What was your biggest mistake or stupid thing you did to your model A this year?
Mine, I filled up the gas tank from a 5 gallon gas can in my front yard, and left the cap on the running board. I live on a corner and when I made the turn, it slipped off and landed in the middle of the street. I didn't notice until after I got home. Yes, I knew where the cap had to fall off the running board while making my first turn.
I found it top-side down after it had been run over a few times. Do they make replacement polished covers?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 12-15-2021, 11:21 AM   #2
arnhemmer
Default Re: Your biggest Model-A mistake of the year?
Syders carries them.
arnhemmer is offline   Reply With Quote
Old 12-15-2021, 11:22 AM   #3
arnhemmer
That's Snyders
Old 12-15-2021, 11:53 AM   #4
Patrick L.
Patrick L.'s Avatar
Selling it !
Old 12-15-2021, 12:03 PM   #5
katy
katy's Avatar
Not driving my A enough.
Old 12-15-2021, 12:16 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Patrick L. View Post
Selling it !
Ooohh!! That's a big one... I couldn't do that!!
Old 12-15-2021, 12:58 PM   #7
Patrick L.
Patrick L.'s Avatar
I really didn't want to, but, don't have room for it now.
But it did go back to the family [grandson ] we bought it from back in '75.
Old 12-15-2021, 12:59 PM   #8
JayJay
Originally Posted by BillCNC View Post
Hey All,
Regards
Bill
I made that mistake this year (and mine was only on the ground for a couple of minutes, but managed to get run over and looks very similar to yours). But my biggest mistake was, I believe, removing the intake/exhaust manifold assembly, which was not leaking, and finding it so badly warped that it would not reinstall without leaking. I ended up replacing the exhaust manifold rather than decking the assembly - time wasted with the engine out of service. Don't get me started on FedEx delivery times.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 12-15-2021, 01:49 PM   #9
GeneBob
Canceling my Burtz engine order.
GeneBob is offline   Reply With Quote
Old 12-15-2021, 02:06 PM   #10
alexiskai
alexiskai's Avatar
I wish I hadn't put the Winfield head on the coupe. I bought the phaeton later in the year, and now I need to go through the hassle of swapping the head over to that one. But of course at the time I didn't know I was going to do that, so does it count as a mistake?
Old 12-15-2021, 02:06 PM   #11
WHN
JayJay
My standard advice is, “If it’s not broken don’t try to fix it”. Model A’s don’t always need to be worked on. One in good shape can go years/many miles without a major problem.
Oil, coolant, spark plugs, tires, they like to be maintained not operated on.
WHN is offline   Reply With Quote
Old 12-15-2021, 03:43 PM   #12
JayJay
I agree. OTOH, standard engineer credo is "if it ain't broke, fix it until it is." And I'm an engineer...
This one was more complex than simply dinking around. The engine had locked up, and I thought it was due to an overheating episode. So I was stripping the engine down to pull it. Turns out the starter Bendix drive had jammed in and that was keeping it from turning over. After I removed the starter it turned over freely. New Bendix drive, all is well. It was when I fired it up after reassembly that I discovered the manifold problem. If I'd taken the starter out (and discovered the jamming issue) before removing the manifolds I'd be golden.
JayJay
JayJay
Old 12-15-2021, 04:42 PM   #13
ronn
as a side- after looking at that cap- reminded me of the time I was cruising to NY with a brand new grill in the back of my f150. stood it upright and strapped it in real good!
well, wasnt good enough. the top lifted off like a kite and was gone on the expressway!
spun around at the next exit to retrieve it, only to find an 18 wheeler had run right over it in those couple a minutes and flattened it like a pancake!
wife wasnt any too pleased........... lol
cant fix my stupid..........
Old 12-15-2021, 05:13 PM   #14
Stingray70
Stingray70's Avatar
The dumbest thing I have done on the A was while changing my front spring. Jacked the car up, removed the lug nuts, and realized the car wasn't quite high enough to get the wheels off. Without thinking, I gave the jack a quick pump and as the car lifted, the right wheel fell off face first. Crushed the hub cap. Grr
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 12-15-2021, 07:45 PM   #15
nkaminar
nkaminar's Avatar
The re occuring mistake I have made this year was forgetting to turn the gas on and having the engine start to stall out. I manage to turn it back on before the engine quits altogether.
Not tightening the fuel line fitting completely at the engine side of the sediment bowl and having gas fumes in the car.
Oh, and the big fuel leak inside the car when trying to tighten the inside fitting to a stripped out sediment bowl. It took about 3 weeks for the gas fumes to completely dissipate. I almost forgot about that one. I think it was the biggest. I kept a fan on the carpet for a week.
Old 12-15-2021, 08:11 PM   #16
ronn
nk- sounds like you like the smell of gas.............
I remember that lovely smell when I used to pump in the 70s.
Old 12-15-2021, 09:04 PM   #17
gdmn852
gdmn852's Avatar
Hello I did the gas cap affair also, but if you ask my wife, it was buying the car!!! But she’s no fun.
gdmn852 is offline   Reply With Quote
Old 12-15-2021, 09:38 PM   #18
JD 1931
JD 1931's Avatar
I did the same when fueling but never found it, had to buy a new repro...
JD 1931 is offline   Reply With Quote
Old 12-15-2021, 09:52 PM   #19
CarlG
CarlG's Avatar
I've done the gas cap thing twice just recently (old age is creeping up on me). First time, I found in on the running board, but only after I had ordered a new one. Second time, I caught it before I left the parking lot.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-15-2021, 09:52 PM   #20
Big hammer
The years not over YET, oh forgot to grease the muffler bearing when I greased the chassis!
To keep from losing my gas cap I put it in my pocket, when you set down you’ll know where it is instantly!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
