04-19-2017, 09:22 PM | #1 |
FS ignition in a B distributor
Hi all, I attempted to search for some information on installing a FS ignitor module in a B distributor and couldn't find any.
Has anyone done this? If yes please tell me how you mounted the module on the B upper plate. Thanks, Herb Neumann Concord CA |
04-20-2017, 12:00 AM | #2 |
Re: FS ignition in a B distributor
Yes Herb, I have done it. I used Pam studs inserted from the bottom of the plate, nuts on top. That way the bottom surface is smooth where the spring contacts it.
A's Always Dave |
04-20-2017, 12:51 PM | #3 |
Hi Dave, thanks for your reply. How did you determine the position the module on the plate so the timing would be correct?
Thanks, herb |
04-20-2017, 09:34 PM | #4 |
A's Always Dave Last edited by 31 Vicky; 04-21-2017 at 02:57 PM. |
