Old 12-27-2019, 12:48 PM   #1
mhsprecher
mhsprecher's Avatar
Default Not really about old Fords
But interesting nonetheless. About using 3D printers to make parts for aircraft. A couple of mentions of the old car hobby, too.
https://www.washingtonpost.com/outlo...lions-dollars/
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 12-27-2019, 08:34 PM   #2
Flathead Youngin'
Default Re: Not really about old Fords
Yes, very interesting. Things are a changing and rather quickly...
I'm ready to print my 32 roadster.....jut hit "print" and it'll be done when I wake in the morning...
"Constipated, can't pass a thing! Don't laugh, bud, your daughter may be in here. They don't call 'em flyn' flatheads for nothin'!"
Hot Rod (Kennie) Holmes
Flathead Youngin' is offline   Reply With Quote
Old 12-27-2019, 09:18 PM   #3
Synchro909
Synchro909's Avatar
It's been a couple of years now since a workshop here used 3D printing to make the core for casting a new engine block for the only remaining Grand Prix Delage in the world. The original had cracked and been repaired too many times so they decided a new one had to be made. At the end of it, this car was saved. I've seen it several times and heard it run - absolutely magnificent!
Here is a link to a press article about it
https://www.abc.net.au/news/2017-03-...ix-car/8310958
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-27-2019, 10:58 PM   #4
redmodelt
redmodelt's Avatar
Synchro909 I saw that one before, out in the sticks and they printed it up. Really cool!
Old 12-28-2019, 01:23 AM   #5
updraught
updraught's Avatar
One hundred years after the 1914 race. A Bugatti wasn't known for its brakes ...
https://youtu.be/Vwwvgkwj8CY
A local story. From what I gather there's a lot of knowledge goes into the programming to produce a part. Hence the value of the team up with the uni.
https://stockhead.com.au/ipo-watch/i...etal-printing/
updraught is offline   Reply With Quote
Old 12-28-2019, 07:27 AM   #6
Gary Karr
Gary Karr's Avatar
Jay Leno's garage has been using one for some time now. The last time I was there they were making some obscure water pump housing.
Gary Karr is offline   Reply With Quote
Old 12-28-2019, 11:28 PM   #7
Jeff/Illinois
Jeff/Illinois's Avatar
That is really cool, the 3-D printer technology. Amazing stuff
Jeff/Illinois is offline   Reply With Quote
Old 12-29-2019, 01:54 PM   #8
Flathead Youngin'
I forgot about this, my son shared this with me about a year ago...
https://www.autoblog.com/2019/10/07/...ini-aventador/
Old 12-30-2019, 07:31 PM   #9
rotorwrench
rotorwrench's Avatar
In aviation and likely many other industrial applications use them for rapid prototyping so they can make sure parts will work together as designed. They can use them for getting core boxes set up to allow for material shrinkage in the process depending on materials required. Stuff still has to be fabricated from the models but getting a correct model to begin with is important and 3D printing speeds that process up a lot. Pattern gears can also be fabricated this way for power transmission systems.
