Old 05-31-2017, 07:02 AM   #1
melisahe
melisahe's Avatar
Default 38 ford coupe
can anyone tell me what is the difference in the "body" between the coupe and deluxe models. I know the grille and fenders are different. Thank you for your time.
melisahe is offline   Reply With Quote
Old 05-31-2017, 08:29 AM   #2
RCS41PU
Default Re: 38 ford coupe
I have a Std coupe. I'm pretty sure the firewall is set up differently at least in the battery area. If you need pictures let me know.
Richard
RCS41PU is offline   Reply With Quote
Old 05-31-2017, 08:41 AM   #3
RCS41PU
Also, the firewall/battery area on a Deluxe looks more like a 39 if i remember correctly, and the Standard looks more like a 37. The stainless side trim on doors, quarters, etc is in a different location on theStd and Del.
Richard
Old 05-31-2017, 08:44 AM   #4
Jack E/NJ
Jack E/NJ's Avatar
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 05-31-2017, 08:47 AM   #5
RCS41PU
Also, a Deluxe will always have 2 wipers, and a Standard can have 1 or 2.
Old 05-31-2017, 08:48 AM   #6
barnfind
my understanding based on prior ownership of a 38 Deluxe:
38 Standard is almost the same as a 37
38 Deluxe is almost the same as a 39 Standard
I have no idea what varies between the similar body styles..
barnfind is offline   Reply With Quote
Old 05-31-2017, 09:26 AM   #7
Pomeroy41144
Pomeroy41144's Avatar
All of the differences between the two 1938 models are explained in detail in the Early Ford V-8 Club of America's reference work titled "The 1938-1939 Ford Book."
Good luck
Pomeroy41144 is offline   Reply With Quote
Old 05-31-2017, 07:02 PM   #8
melisahe
melisahe's Avatar
Thanks Guys! I've got what I've been told is the Standard. I know the fenders and hood parts that came with it are Standard but the body had two wiper ports witch had me wondering. I've got the green bible so I can look up the fire walls. Appreciate the help, Thanks
