03-10-2020, 12:37 PM | #1 |
Neg. Ground
Went to charge the battery in my stock 35. Noticed the guy who did my wiring hooked it up Neg. ground. Wouldn't that be running the current the wrong way through the coil? (helmet) All gauges work except the 36 feul gauge and sender. What is involved to changing it back to positive Ground?
03-10-2020, 01:34 PM | #2 |
Re: Neg. Ground
If you have a l935 Ford it had a positive ground when it left the factory.
03-10-2020, 01:41 PM | #3 |
Re: Neg. Ground
One thing we need to know; is the car been converted to 12 volts? If so, it's not a problem. If it's still 6 volts, I would seriously consider making the effort in correcting the situation back to stock.
03-10-2020, 02:23 PM | #4 |
Re: Neg. Ground
It is 6 volts
03-10-2020, 02:40 PM | #5 |
Re: Neg. Ground
Did "the guy who did the wiring" make some changes or just put the battery in backwards? I think a talk with him would be in order if possible.
03-10-2020, 04:17 PM | #6 |
Re: Neg. Ground
Time for a warranty repair from the guy that did the wiring... |
03-10-2020, 04:53 PM | #7 |
Re: Neg. Ground
A new harness was installed so I am sure everything is hooked up right. He just didn't realize old ford are pos. grd. He did install directionals so I will have to check those for proper wireing
03-10-2020, 05:45 PM | #8 |
Re: Neg. Ground
Should be able to just switch the terminals on the battery except for the generator issue. How did he get the generator to work if he didn't understand the electrical system? Anyway, the polarity on the generator will have to be re-flashed.
03-11-2020, 10:53 AM | #9 |
Re: Neg. Ground
When I received my 30 Tudor the seller was nice enough to include a new battery. He hooked it up negative ground. Hard to start, when running ran off of generator power. Reversed battery connections, polarized the generator. Too late, the oops had fried the generator relay and because it had sealed beam headlights I just ended up going with a 6 volt alternator.
Long story just to say pull the generator and see if it was damaged... Chap |
03-11-2020, 11:05 AM | #10 |
Re: Neg. Ground
I am kinda amazed that the thing even ran. These old Fords are amazing.
03-11-2020, 02:54 PM | #11 |
Re: Neg. Ground
Well, the only real issues should be the coil and the generator. A coil will work with reversed polarity, it just reduces the output (some estimates are by 20%, but I have no real idea). The generator is a different matter, not sure how they work with the polarity reversed, but I'm sure it's not good.
03-11-2020, 04:00 PM | #12 | |
Re: Neg. Ground
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 03-11-2020 at 05:56 PM. |
03-11-2020, 07:24 PM | #13 |
Re: Neg. Ground
Ya, I was just wondering how it worked when the battery terminals were reversed in the first place.
03-12-2020, 08:54 AM | #14 |
Re: Neg. Ground
My car "kinda ran" with the battery in backwards. Had to keep the RPM really up there to get down the street.
I once had a flathead where the timing marks were off three teeth. Ran, but sputtered and backfired a lot. Like Tubman said, "these Fords are amazing... Chap |
03-14-2020, 04:00 AM | #15 | |
Re: Neg. Ground
Gesendet von meinem ANE-LX1 mit Tapatalk |
