03-08-2019, 07:57 AM | #1 |
35 ford four door
Need help can’t find quarter window that opens backwards need the seals and all the stuf that goes with it
03-08-2019, 08:04 AM | #2 |
Re: 35 ford four door
Try Joe's Antique in Uxbridge ,Massachusetts 508 378 3980. Welcome to the Barn .
03-08-2019, 08:16 AM | #3 |
Thanks but Joes has nothing
03-08-2019, 08:19 AM | #4 |
With,
Hang in there JM '35 will be here shortly. Charlie ny |
03-08-2019, 09:20 AM | #5 |
on a 36 four door with the opening window, I had to use seals for 46/48 and cut them down to fit. not a hard job as the pivot points and latch were in the same place, just had to cut to correct length and super glue back together
03-08-2019, 09:24 AM | #6 |
03-08-2019, 09:47 AM | #7 | |
Withrick, my favorite driver is a '35 fordor sedan with those quarter windows that come back when you crank them open. However, since mine work well, I've never had to work on them, and don't know who would carry the parts you need. I thought I did see seals for them at one time in Bob Drake's catalog. My suggestion would be to contact Michael Driskell @ Third Generation Automotive, and see if he can help with any parts you may need. If he doesn't carry the parts you need, he most likely knows who does. Good luck!!
03-08-2019, 10:28 AM | #8 |
Thanks I’ll try that
03-08-2019, 11:35 AM | #9 |
I'll second what JM 35 Sedan said. Call Micheal at Third Gen Automotive.
03-08-2019, 12:51 PM | #10 |
03-08-2019, 01:33 PM | #11 |
Withrick, For the rear quarter windows in my 35 fordor I purchased lengths of fuzzie strip from Steele Rubber Co, look here; https://www.steelerubber.com/window-...ip-inners-only
Can't remember exactly which one I bought, however, I chose the non-stainless bead variety, 7/16" wide, and it came in 6 foot lengths. Use the garnish mouldings to get the right shape, ie, use the RH moulding to make two, one for LH body and one for the moulding, and vice versa. Go slow and easy, this stuff bends very nicely, without kinking, start at the most acute angle,[the rearmost part], you'll find as you form the rest, you'll need to keep going back and rework the previously formed sections, as, as you form the curves, the resulting stretching of the outer edges tends to straighten out the earlier formed curves. Once you've got the first one made, you'll have more of an idea, and you'll make the rest faster.
Unfortunately, two half wits don't make a whole wit! Last edited by Brian; 03-08-2019 at 02:00 PM. Reason: further info |
03-08-2019, 01:49 PM | #12 |
And the front section [the bit that runs down the pillar], is a channel section
03-08-2019, 01:50 PM | #13 | |
03-08-2019, 03:39 PM | #14 |
03-08-2019, 07:44 PM | #15 |
Welcome to the ‘Barn. Now that’s yellow! Good luck in finding what you need. Mike
03-09-2019, 05:16 AM | #16 |
03-09-2019, 07:18 AM | #17 |
Withrick….I have a 37 half-ton stake street rod that color yellow. I like it. My wife picked out the color, I said, "yes ma,am" and it's been that color since the mid '90's. When I park it out in the back yard during the Summer, it will attract half a dozen or so honey bees.
03-09-2019, 10:17 PM | #18 | |
