09-24-2020, 05:23 PM | #1 |
49 woodie rod radiator
Got the radiator moved forward 2-3 inches, enough to have an 18 inch mechanical fan on the Mustang 302 instead of a 16 inch electric fan. Fabbed a fan shroud and fan is 1inch from radiator and shroud hole is 20 inches for the 18 inch fan. It's cool today, 74F vs the normal 95F but idled the engine 15 minutes and never got the 160F thermostat to open. Will take thermostat out and run some radiator flush next step. Has got FITech GO EFI on it. Timing not set by EFI. Learned a very hard lesson on hot rods. Buy one from somebody who knows what they are doing. Had to fix just about everything that was rodded. Not expensive but time consuming and mentally challenging.
How should I set the timing deg at what RPM? Has an MSD distributor with vacuum advance.
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 09-24-2020 at 05:38 PM. |
