Old 08-10-2020, 08:21 PM   #1
old Tom
Default Isky or Potvin
Did the late Jazzy Nelson use a Isky or Potvin cam in his FH powered car. I do know it was pretty fast for it time. The Bean bandits used to respect it.
old Tom is offline   Reply With Quote
Old 08-10-2020, 08:27 PM   #2
Pete
Pete's Avatar
Default Re: Isky or Potvin
505A Isky.
Old 08-10-2020, 08:34 PM   #3
old Tom
Does the 505 represent the lift as the 404 did?
Old 08-10-2020, 09:00 PM   #4
Pete
Pete's Avatar
Approximately. It has .515 lift.
Old 08-10-2020, 09:11 PM   #5
old Tom
That's amazing. I never heard of that cam before. I wonder if Tom Beaty(sp) was aware of it or maybe it was not a good cam for the salt flats.
Old 08-10-2020, 09:35 PM   #6
Pete
Pete's Avatar
Isky only made 3. Only one is left.The 3rd one dissappeared.
I talked to Tom many times at Bonneville but we never discussed cams.
I am sure he was aware of it. It would work very well at Bonneville.
Old 08-11-2020, 09:03 AM   #7
old Tom
Have you ever tried to grind a 505A or would it be impossible to do without a core to start with?
Old 08-11-2020, 02:28 PM   #8
Pete
Pete's Avatar
I have done one.
Old 08-12-2020, 08:07 AM   #9
Ol' Ron
Ol' Ron's Avatar
Pete, what kind of springs do you use for that? Is this a roller cam?
Old 08-12-2020, 01:34 PM   #10
Pete
Pete's Avatar
Springs are 4 coil special. Similar to 410 sprint car engine.
This is a radius lifter type. Uses same lifters as 404A.
Old 08-12-2020, 02:40 PM   #11
Ol' Ron
Ol' Ron's Avatar
Rana 404 once, wazent happy with it!! 400 jr ran better, but that was probably my fault.
Old 08-22-2020, 01:28 PM   #12
lonewolf
505 lift. I take it you need a billet cam with no cam bearings in the block? Or you modify the block for that much lift?
lonewolf is offline   Reply With Quote
Old 08-22-2020, 03:25 PM   #13
Pete
Pete's Avatar
Yes on billet core.
Yes on running journals in bare block.
No mods to block for lift.
Old 08-22-2020, 05:38 PM   #14
Bored&Stroked
Bored&Stroked's Avatar
And here are some pictures of the 505A that Pete is talking about - with some side-by-side shots against the 404A.
I have yet to run the cam, need to build a very "special" engine for it.
And Jazzy Nelson's Coupe . . . probably the fastest drag coupe that ever ran a flathead. Jazzy ran the 404A quite a bit, but "wanted something bigger - and a secret grind" - that is when Ed made the 505 for him.
