07-15-2020, 01:26 PM | #1 |
Elec novice
40 coupe w/48 block. I had the gen rebuilt last year. Rechecked again a few weeks ago along with the regulator. Dash gauge comes up slowly mid way and then into the yellow, then to green. Batt shows 6.3 volts.
Where on the regulator do I measure voltage. As always Thanks in advance. Paul in CT |
07-15-2020, 02:05 PM | #2 |
Re: Elec novice
From one novice to another, I would check from 'A' to ground going into the regulator and from 'B' to ground coming out of the regulator.
07-15-2020, 02:14 PM | #3 |
Re: Elec novice
I’m just a hack but I check voltage at the battery before I start then recheck after the car is running to compare readings
"I can't cry as long as I know the Lord has risen " |
07-17-2020, 01:20 PM | #4 |
Re: Elec novice
OK, nothing at A or B. Also nothing (maybe o.3 or so) on each post of the gen. Gen and regulator just checked. Any ideas?? Have had it running and batt shows 6.2-6.3V, still pos ground.
Paul inn CT |
07-17-2020, 02:14 PM | #5 | |
Re: Elec novice
Paul not sure taking readings on the regulator is the way to go. Heres what I do to test for output using your meter first take a reading at the battery before you start the engine note the reading. Then start the engine and take another reading obviously you want to see a higher voltage reading with the engine running if you see an increase in voltage write that down. Now if you did see a higher reading in the previous step now turn the head lights on this will add load to the charging system which if working correctly should carry the added load of the lights being on. This means the reading at the battery with the car running and lights on the reading should be above 6 volts. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-17-2020, 02:38 PM | #6 |
Re: Elec novice
07-17-2020, 04:39 PM | #7 |
Re: Elec novice
Ronnie and Bob C: WIl try this tomorrow. Dash voltage meter still only goes to a little past the red zone into the yellow..
Paul in CT |
07-17-2020, 07:13 PM | #8 |
Re: Elec novice
Not running a fully charged battery should read in the 6.3 - 6.4 volt range and the B terminal on the voltage regulator should read the same as the battery minus any voltage loss in the wiring. Running (with the rpms up) the battery should be seeing 7+ volts, but this is somewhat dependent on the system load (light on, etc).
07-18-2020, 06:32 AM | #9 |
Re: Elec novice
Batt terminal - to regulator case+ engine RPM need to be increased to see full generator output. Use an analog meter 7.0 to 7.7 v is good but 7.2 to 7.5 is better.
First with engine off turn on country headlamp beam for one to two minutes then measure battery voltage at the regulator with headlights off should be 6.25 to 6.6V if not recharge the battery first. Then run engine at medium speed and with engine and regulator warm measure the highest voltage. You can see it is important your voltmeter is accurate. |
