01-12-2011, 01:44 AM | #21 |
Re: Babbitt Bearings
Our longest babbit life has been 25k so far with the bearings being tightened up just once. Our worst one has been 150 miles before center main was gone. We also had 2 other babbit jobs fail under 1000 miles. And yes we do proper break in periods. The new engines were all driven 40 mph. After the three that failed within 2k miles we switched to inserts and will never go back to babbit.
Cowtown A's |
01-12-2011, 02:05 AM | #22 | |
Re: Some cap measurements
There are some caps that have been filed so much, that we had to pitch them. So Bob, what would be your conclusion to your post, and or your hypothesis. Thanks Herm. |
01-12-2011, 02:27 AM | #23 | |
You can't blame the Babbitt, it doesn't take much to know where the blame lies. I had bearings in the Blue Plymouth Coupe, car No. 42 in the China to Paris race, and it didn't have any bearing trouble, and in all had about 10,11 K. on, and very hard miles. Its a good thing that the guy that put in your inserts, knew what he was doing, as your choices are about dried up. Thanks Herm. |
01-12-2011, 03:14 AM | #24 |
Are you saying that a bad insert job means the block is scrap?
But a bad babbitt job can be salvaged? |
01-12-2011, 09:54 AM | #25 |
Bad babbitt can always be chopped out and new babbitt poured, many times when an insert fails the bore (block) is damaged --and the crankshaft---then you need to look for a different insert that is for a larger outside bore,yet still has the proper inside bore and have the crank ground, or replaced.
A modern engine with inserts that has a spun main usually will have the block and crank replaced ---or $$ machine work. A babbitt engine with a failed main many times just needs the babbitt replaced. An insert is easier to replace if it is caught before failure. I have had 2 babbitt failures, the rear main, and a rod, both failures did no crankshaft damage. The babbitt I paid to have done failed, gave me the courage to do it myself--so far that has lasted 4x the what the professional job did, and I have tried to break it. Done properly both inserts and babbitt will work for very long times, babbitt can always be redone, but with inserts you have to hope whatever inserts that were used can be found in the size you need. |
01-12-2011, 09:59 AM | #26 |
01-12-2011, 10:10 AM | #27 |
I have read a lot of discussions about the thickness of shim packs available today and I am just curious as to the ability to just make your own shims. Couldn't you just get some .003 shim stock and fabricate your own shims possibly using steel shim stock to get away from the softer brass type availble now? Just curious.
01-12-2011, 11:38 AM | #28 |
Another thing to consider, what kind of babbitt was used? High tin(correct) or high lead(wrong).
01-12-2011, 12:06 PM | #29 |
Brian,
Was the engine knocking with the bearings in this condition? Also, what did the oil look like on the dip stick-where there bits of babbitt?
"no one knows more than everyone" |
01-12-2011, 12:17 PM | #30 | |
Very good Kurt, Herm. |
01-12-2011, 02:44 PM | #31 | |
01-12-2011, 04:29 PM | #32 | |
01-12-2011, 07:27 PM | #33 |
Thanks for the input on shims Herm. I really had no idea that the alignboring was done and actually cut any shim overhang. Makes sense though. I know I have taken a motor apart and it did seem to have a mix of some brass and some steel. Obviously not real well put together. I enjoyed your response and learned something so thats all good.
01-13-2011, 12:46 PM | #34 | |
Hello Kohnke. I see you're still singing the babbitt tunes. You've seen a variety of engines go through your shop. What in your opinion would be the longevity of thick babbitt bearings, the thicker the better, if they were used to replace the inserts in an engine like in my 70 Vette ... with 11.25 to 1 compression ratio, 460 horsepower and 490 ft.-lbs. of torque? |
01-13-2011, 05:13 PM | #35 |
"Thick babbitt is much stronger than thin in cases where it can't be tinned." Read this statement carefully, this is absolutely true and doesn't obviate your point at all, Larry. Explanation: If the cast iron isn't tinned and adhesion is poor, the babbitt can't transfer stress to the saddles. If tinning is done properly and adhesion of the babbitt is excellent, then stress on the bearings is transferred to the saddles, which reinforce the babbitt. Perfect analogy is a composite material like fiber-reinforced epoxy: if the fibers adhere well to the resin, they reinforce it and the strength is excellent. If they don't adhere well to the resin, then no stress can be shared by the fibers and the strength can be lower than with no fibers present. Rigid, strong fiber = iron bearing saddles; softer, weaker epoxy matrix = babbitt. Adhesion is absolutely critical, and proper tinning is only way to get it.
In cases where adhesion is excellent (read: properly tinned), thin babbitt will be stronger. Insert bearings: great adhesion allows thin babbitt to share strength and stiffness of steel shell backing. If thin babbitt in an insert bearing adhered poorly, the bearing would last about 1 revolution. But thick babbitt, adhering poorly, can last 1000's of miles (but maybe not much longer!). Kindest regards and loving this sort of discussion, Giles Last edited by gilitos; 01-13-2011 at 05:16 PM. Reason: clarity |
01-13-2011, 07:03 PM | #36 | |
I don't Know, what in your opinion would be the longevity of two of your Model A heads in your 70 Vette--- with 11.25 to 1 compression ratio, 460 horsepower and 490 ft.--lbs. of torque, even if you could get all of your spark plugs actually screwed in. Oh, Ya, Model T block, with babbitt, and ether a RAJO, or Gallivan, with duel over overhead ( thats means cams brumy) ran 14 to 1 compression, no Bearing problems. Thanks Brumy, Kohnke. Last edited by Kohnke Rebabbitting; 01-13-2011 at 07:09 PM. |
01-13-2011, 07:25 PM | #37 |
01-13-2011, 08:23 PM | #38 | ||
Thanks for your input, Giles. However, I don't care for thick babbitt even though it will work on a Model A. Pete, below, from another thread put it in words better than myself: Quote:
. Last edited by Larry Brumfield; 01-13-2011 at 08:50 PM. Reason: spell |
01-13-2011, 08:27 PM | #39 | |
01-13-2011, 08:45 PM | #40 | |
And cast iron CANNOT be tinned, EVER. |
