Old 05-09-2014, 01:37 PM   #1
oldskool
oldskool's Avatar
Default eastwood carb paint
anyone used eastwood bronze carb paint with good results or a waste of time?
oldskool is offline   Reply With Quote
Old 05-09-2014, 02:51 PM   #2
ford38v8
ford38v8's Avatar
Default Re: eastwood carb paint
It's not a waste of time if you're sure you want a bronze painted carburetor.
Alan
Old 05-09-2014, 03:57 PM   #3
oldskool
oldskool's Avatar
my concern is how it holds up to menthol gas
Old 05-09-2014, 04:19 PM   #4
Bruce Lancaster
It will make your carb look like an authentic Christmas tree ornament!
Appearance is very questionable, IMHO, but quality is phenomenal...I bought a 97 so painted to clean and fix, and discovered that no liquid I owned would touch the stuff even over a month of soaking. I finally bought a new bucket of carb cleaner, which was about $40, and THAT need a week to kill the @#$@##$. All the floating bits of tinsel had to be cleaned off of anything I put in that carb cleaner after that, too.
The various types of stuff I tried before the new carb cleaner involved gasoline and a couple of different alcohol type paint thinners, in fact anything I could find that did not eat zinc, so I would be astounded if alcoholic gasoline had any effect.
Old 05-09-2014, 04:26 PM   #5
ford38v8
ford38v8's Avatar
Oh, boy. Menthol gas and alcoholic gasoline. Both youse guys are comical!
Alan
Old 05-09-2014, 04:34 PM   #6
Bruce Lancaster
Together they make a Blue Russian? Or maybe just a dead one...
Old 05-09-2014, 05:41 PM   #7
FordCustom
A blue Russian is one that makes questionable movies?
FordCustom is offline   Reply With Quote
Old 05-09-2014, 06:23 PM   #8
Charlie ny
os,
The Eastwood carb paint is not gasohol proof.....it is gasohol resistant. If
one happens to reside in an over-regulated asylum like New York State chromate
plating is verboten without proof of proper disposal and a permit. If I built 1000
plus carbs each year the cost of the regs might be affordable.
Here's how I use the stuff, not that anyone is asking.....get the carbs as
clean as possible, media blast, blow out all passages then rinse in lacquer thinner,
and dry thoroughly . In a well ventilated area warm the part up 'warm to the touch'
then just DUST the part. I'm not a fan of using this stuff as a paint, I think as a paint
it looks phony....however as a sort of translucent stain ,shall we say, it gives a
rather nice appearance. The warm up part of my proceedure enhances durability and
hardens the finish.
This is only how I do it...I certainly respect everyone else's thoughts and proceedures.
Charlie ny
Old 05-09-2014, 06:38 PM   #9
Mr_Coupe
Mr_Coupe's Avatar
Good info. I was going to use that stuff.
Mr_Coupe is offline   Reply With Quote
Old 05-09-2014, 07:57 PM   #10
Vergil
Vergil's Avatar
I didn't paint a heavy coat on my carbs and this is what they look like ... I like the paint
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 05-09-2014, 08:23 PM   #11
1952henry
1952henry's Avatar
I'll concur with posts 8 & 10. Done well, it looks good.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-09-2014, 11:20 PM   #12
Fortunateson
Holy shit! Invisible carbs! Maybe if I paint my plates like that I won't be tolled and if I paint the whole car I won't get caught in radar!
In other words... I can't see the pic.
Fortunateson is offline   Reply With Quote
Old 05-10-2014, 06:20 PM   #13
37fordpickup
I checked Eastwoods catalog and can't find a black paint recommended for the base of a 97. What paint are others using?
37fordpickup is offline   Reply With Quote
Old 05-10-2014, 07:09 PM   #14
Mike..Yorba Linda
I used, with great results, black epoxy paint.....Rust-oleum brand..... Also, I coated my carbs with Alodine....
Mike..Yorba Linda is offline   Reply With Quote
Old 05-10-2014, 07:31 PM   #15
1952henry
1952henry's Avatar
I don't use paint now, I have my own blackening process. But when I did use paint, I used Rustoleum Appliance Epoxy.
Old 05-12-2014, 12:53 PM   #16
Bruce Lancaster
A lot of the Model A people with their iron Zeniths swear by hot fuel proof paint from the hobbyshop...it is made to survive the nitromethane loaded fuel used by model airplane engines. I've never tried it, but it sounds like a good idea for bases.
