06-15-2010, 10:30 AM | #61 |
Re: Flathead Fun this Weekend
Hey, Vic, you and I are having loads of flathead fun!!
06-15-2010, 10:44 AM | #62 |
Tom, After 45 years of messing with these Flatheads I'm still trying to convince myself that this is fun Don't ya just love it
06-15-2010, 01:03 PM | #63 |
You could start it, just hot wire it neg to coil,you may also be 180 out of time.Top dead center the rotor should be straight down 6 o clock.and if the cap is marked #1 is left or right of cap clip.Did you hear that motor run?
06-15-2010, 01:08 PM | #64 |
The motor was running when my friend pulled it out of his '51 F-1 to install a "Full House" Flathead he built. I plan on "hot wiring" it this Saturday to get it to fire and after that, I'll try to trace the problem with the starter button... Something simple I'm sure, we'll find it.
06-19-2010, 12:39 PM | #65 |
It’s ALIVE, it’s ALIVE... We got the 8RT that we put in the '53 Panel to fire up today and she is sweet. The problem was (I hate to admit) I had the plug wires 180 out at the distributor cap... It's the first time I've ever made a mistake. Pete, she runs really well, all we need to do now is a little tweaking on the timing and carb as she kicks up a little under a load in second gear. I' am a happy camper. Now on to the next project.
06-19-2010, 01:06 PM | #66 |
If it aint broke, don't fix it! |
06-19-2010, 03:09 PM | #67 |
Vic, Glad to hear that motor started. It's got to be that carb making it run rough. Ha,Ha.
I bought my next project yesterday a 1940 panel. It's needs major work but that what I love. I will post pictures next Friday. Pete |
06-20-2010, 03:32 PM | #68 |
Pete, I think a couple of the plug wire ends might need to be replaced and, as usual, I don't have any extras in my stash... I'll have to get some this week. I'm sure we'll get the bugs out. The '40 Panel sounds like a neat project, can't wait to see some photos. Vic
06-21-2010, 09:13 AM | #69 |
Good for you, Vic - sounds like you got a winner!
06-21-2010, 11:26 AM | #70 |
Thanks Tom, I sure hope so. Here are a few photos of the new 8RT between the fenders, etc.
06-21-2010, 01:42 PM | #71 |
06-21-2010, 02:05 PM | #72 |
Tom, thanks again. It took me half the day to clean it out... While it was out of commission I was using it as a catch all for parts, etc. from some of our other Flatheads. This Flathead sounds like it'll be a good strong runner. I just called NAPA and ordered a new set of 7mm plug wires, I'll pick them up tomorrow and install them at lunch time.
06-22-2010, 09:36 AM | #73 |
Lookin' good!
Obsessed with all things 1936 Ford since birth... thanks Dad. |
06-22-2010, 11:23 AM | #74 |
Thanks. I'm still working out some of the kinks; I put in a new set of plug wires earlier and took it for a drive... Still breaking up under a load in first and second so... I poured a little MMO down the carb while the motor was running, went for another ride and things did improve, I think I'll drive it around a bit more today and if things don't continue to improve, I'll check the points and maybe tweak the timing again... We'll get it working right.
07-08-2010, 09:14 AM | #75 |
Problem solved! It turns out that the vacuum advance in the distributor was not working as it should. My friend Art had an NOS distributor that the let me use to see if the truck would run right.. It worked! I'm not a big fan of the Ford vavuum advance and I usually swap out the stock unit for a Mallory dual point, that's next, but for now I'm using Art's NOS distributor and the truck is running really well.
07-08-2010, 11:14 AM | #76 |
cool, i had a falcon with a 170 and when the vacuum advance would not work right it would drink gas
06-04-2013, 03:40 PM | #77 |
I,m a new boy working with trucks ,cars bikes no problem, trucks ,I just luv em
06-04-2013, 05:25 PM | #78 |
What ended up being the "broken" part of the old flat head?
06-04-2013, 05:35 PM | #79 |
It turned out to be the head gaskets; they just crumbled when we removed the heads... The big surprise was, it was a Merc Flathead. Before we installed new head gaskets, we flipped it over, pulled the pan to check the main and rod bearings, the crank was stamped 8CM… We bottomed out a piston and stuck a ruler in the cylinder to make sure it was a 4” stroke. Now that Flathead resides between the frame rails of our ’51 F-1.
06-04-2013, 07:49 PM | #80 |
A MERC in the F-1 !!! No wonder that truck ran down I-75 so well. You've a hot motor in the little red truck.
