Old 11-18-2014, 11:18 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Pulled my Head to Look Inside the Top of the Engine
Rich, no sleeves. I've never had a sleeved engine overheat or give problems.
I did see the picture of one installed improperly and it really made a mess when the sleeve went down and the piston rings caught over the top of the sleeve.
Old 11-18-2014, 11:24 PM   #22
darrylkmc
darrylkmc's Avatar
Tom,
My original Phaeton engine had .045 pistons, and I had to bore it out to .080, but it had been sitting without a head on for decades.
Maybe you can procure some .025 pistons and do as John suggested.
Darryl in Fairbanks
+25 and warming
darrylkmc is offline   Reply With Quote
Old 11-18-2014, 11:25 PM   #23
KR500
KR500's Avatar
Tom, You said you will rigid hone the cylinders to get all 4 cylinders the same. I assume you are taking engine completely down? If you replace valves you might also replace valve seats. Is the engine equipped with adjustable lifters? You never know what kind of can of worms you will find from previous gearheads who have had their hands in the mix. Good luck!
KR500 is offline   Reply With Quote
Old 11-18-2014, 11:39 PM   #24
Tom Wesenberg
I would never install valve seats unless it really needed them to repair a crack or very badly recessed original seats. My valves all set up enough, so I know they aren't badly recessed. I'll know more after I tear the engine completely down.
Old 11-19-2014, 12:45 PM   #25
CarlG
CarlG's Avatar
I had 2 valve seats (Exhaust 3&4) decide to take a hike this past summer. 600 miles from home!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
