11-13-2014, 09:48 AM | #1 |
Champion Plug # W18
Is this plug still available or has it been replaced, and if so, what is the new #?
Thanks. |
11-13-2014, 10:00 AM | #2 |
Re: Champion Plug # W18
It is still available. They now list it as Champion 518.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
11-13-2014, 10:57 AM | #3 |
The order number is 518 , Its still Champion W 18
11-13-2014, 03:30 PM | #4 |
Thank you very much!
11-13-2014, 07:20 PM | #5 | |
I got a set just about a month ago
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
11-14-2014, 05:32 AM | #6 |
is this 518 hotter then the w16 kevin |
11-14-2014, 06:25 AM | #7 |
11-14-2014, 09:13 AM | #8 |
I just bought 4 - W18 spark plugs ( 10/28/14) from Mike's A Fordable Parts - Maysville, GA 30558
11-14-2014, 09:28 AM | #9 |
If you still have soot issues on your plugs and you've tweaked the timing and carb enough to know they are OK, then the W18 or 518 is the plug to go to? Running Motorcraft TT10's now.
11-14-2014, 11:40 AM | #10 |
Its good to see that a model A parts vendor is now offering the Champion W18 spark plugs. They all should !!! The W18 is the best spark plug for the driver model A considering the way most are driven.
11-14-2014, 12:10 PM | #11 |
Just ordered them.
Thanks again to all of you. Will have more ??? coming your way when I start to redo the brakes w/cast iron drums and floaters. Loubob |
