09-09-2014, 09:07 AM | #1 |
Installing gooseneck on head
I have a small leak on the middle front side between the head and the gooseneck on my 28 coupe. When I installed it, I made sure the surface of the gooseneck was completely flat by sanding it flat on sandpaper laying on some plate glass. I believe the head surface is already flat. When I originally installed it, I used a thin paper/cardboard gasket with Permatex. Obviously I didn't do something right, as it leaks. I used paper matches on the outer ends to prevent the gooseneck ears from cracking. I was thinking of using a more authentic thick gasket similar to the asbestos type used by Ford originally. Would using paper matches work as well on the thicker gaskets? I am concerned about cracking the gooseneck when I torque the 2 bolts to 55 lbs. I would appreciate any suggestions on how to prevent the chance of cracking the gooseneck when tightening the head nuts and making it leakless.
Rusty Nelson |
09-09-2014, 09:25 AM | #2 |
Re: Installing gooseneck on head
Rusty: What I do is to forget about the gasket all together and use a thin smear of RTV to seal it up, it won't leak and haven't broken a neck. When it is dry, take a razor knife and trim around the edges and it is almost undectable.
Mark in MT
Mark in MT Always looking for another opportunity to be wrong. |
09-09-2014, 09:33 AM | #3 |
If the gooseneck is flat, and the head as well, the matches are doing nothing but causing the leak as they are holding it from full contact. I pull the nuts down snug with a regular gasket, and permatex, making sure to alternate from side to side. Then torgue the head using the correct pattern. no problems
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
09-09-2014, 09:36 AM | #4 |
i always use the thick copper gasket on the outlet neck. never cracked one or had a leak using them.
09-09-2014, 09:40 AM | #5 |
I guess I am the bull in the china closet as I have snapped two over the years. None since I started just using RTV. I have used the thin paper as well as the thick copper in the past using the match trick as well. I have never had a problem with leaking using the RTV method.
Oklahoma City Model A Restorers Group. |
09-09-2014, 10:11 AM | #6 |
What kind of sealer do you use with the thick gasket? Rusty Nelson |
09-09-2014, 10:16 AM | #7 |
09-09-2014, 10:39 AM | #8 |
I also only use the original type copper filled gasket with no sealer, and have had no problems or leaks.. And this for F/P..
09-09-2014, 10:39 AM | #9 |
Rusty, the reason why they break is because people do not take the time to restore both surfaces. In your case, you cannot use a sealer as you will receive a deduction. Take the time to level both the gasket surfaces with a file or in the Mill, then use a copper gasket that has been annealed and it will be perfect without any leaks.
09-09-2014, 11:04 AM | #10 |
I've used both type gaskets over the years and have broken several water necks in 54 years. When I used gaskets I had better luck with copper clad gaskets with Permatex , NO matches and broke very few. I now do as Mark in post # 2 and use no gasket and have never broken A single one that way . I apply a coat of clear RTV silicone and let a set a moment before installation of the upper neck. With some heads and thicker repro water necks you can run out of stud length before the nut tightens and using no gasket also solves this problem.
09-09-2014, 11:53 AM | #11 |
I have broken two when helping a friend who was using paper gaskets. I haven't broken any when using a thin coat of silicone only. I also haven't broken any when using the copper gasket. I usually spray the top and bottom of the copper gasket with Copper Coat, but I'm sure it isn't really needed. I do check the outlet with a straight edge and draw file it flat or even slightly concave in the center. I like to tighten the nuts in at least 3 stages, and when I reach 45 lbs. I let it set overnight and give them another torque to 55 lbs. then let it set again and recheck for 55 lbs. Then I recheck several times after short engine runs until it stays at 55 lbs.
09-09-2014, 12:52 PM | #12 |
No gasket!
09-09-2014, 01:12 PM | #13 |
I wonder if alujimum re-pro necks would be less prone to breaking??????
Bill W.
09-09-2014, 01:27 PM | #14 |
I've wondered the same. I've got one in my collection of stuff. I figure it would be the choice if I ever used an aluminum head .
09-09-2014, 01:39 PM | #15 | |
The aluminum one worked ok with Minerva's iron head. I bought it cuz it looked polished, in the catalog pic, it wuzn't polished, just rough cast, with a nice Ford logo on it. I didn't paint it, but it received lots of compliments! Bill W.
09-09-2014, 02:24 PM | #16 |
This one won't break. (No gasket, just silicone sealant)
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 09-09-2014 at 11:17 PM. Reason: add pix |
09-09-2014, 02:48 PM | #17 |
If you haven't broken at least one water neck, you probably haven't replaced one. Many of the old cast iron necks have cracks between the ears and the body that are almost impossible to detect. We usually just replaced them with repros to save time and trouble.
09-09-2014, 04:05 PM | #18 | |
I jist went out to my little museum and checked .. Thet aloonieum water neck thet I've got is fer a 29 .. Iffen you want it its yourn.. It ain't rough cast and orten to be too hard to polish up. You could jist put it on vermin fer a purty !!!!!!! Send me a PM and I'll sack it up and send it to ya priority mail. Yer brother Purdy . |
09-09-2014, 04:11 PM | #19 | |
sorry couldnt resist |
09-09-2014, 04:20 PM | #20 |
That would be ok. I've had it for years. Tried to sell it once but nobody would give anything for it. Brother Bill can just have it for a purty if he wants it . Its really a good water neck that is just begging to be used
09-09-2014, 07:54 PM | #21 |
Now that's Model A camaraderie! And putty good parts to good use!
I concur guys.. I surface them on my resurfacer, also the head surface if I have a head off. I have never broken one yet without a gasket and just RTV. Of course I don't leave any witness to be seen. Larry |
