Old 08-01-2020, 07:25 PM   #1
qmdv
qmdv's Avatar
Default 1/4 inch hole in shifting tower sloppy
On my 39 transmission, the little 1/4" pin that the slot in the shift lever ball slides over and goes in the hole in the shifting tower is sloppy A letter F drill is perfect. I could cut of a little piece of an F drill and use that . I have been told that you should use softer steel than a drill bit. Can I heat the bit to cherry red and let it cool slowly to anneal it. Is that going to be soft enough
qmdv is offline   Reply With Quote
Old 08-01-2020, 07:54 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1/4 inch hole in shifting tower sloppy
Most drill bits have the chuck end softer than the cutting end. I personally
would not worry about using it, if it does the job (and without any heating)
Old 08-01-2020, 08:11 PM   #3
alanwoodieman
I have seen those holes and the slots drilled/ground to fit 5/16" drill bits, I would prefer you use the drill bit as they last a long time
Old 08-01-2020, 09:00 PM   #4
qmdv
qmdv's Avatar
5/16 seems extreme. I will use an F bit
Old 08-02-2020, 07:59 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
I see no reason to soften the pin - just use a cut-off wheel to carve a piece off the end of it .
Old 08-02-2020, 01:50 PM   #6
Hal Beatty
Hal Beatty's Avatar
What B & S said... I did that on my shifter; works well.
Hal Beatty is offline   Reply With Quote
