05-06-2017, 11:00 AM | #21 | |
Re: New block
Tod |
05-06-2017, 11:01 AM | #22 |
Re: New block
05-06-2017, 11:09 AM | #23 |
Re: New block
First issue improving the block is that it won´t be allowed at historic racing.
So either a high nickel std 59AB block for trying to get it aproved in classic racing...that will be a fight... Or an all out fairly stock looking 59AB raceblock. |
05-06-2017, 11:13 AM | #24 | |
Re: New block
Basically, I design the block. Then I decide how I want to cast it. I then design the tooling to facilitate the pouring process. Sometimes changes to processes are necessary due to different foundry methods and capabilities. The auto makers do things a certain way (with billions invested) to make castings as cheap as possible and as quickly as possible. For example, Ford foundry in Cleveland was producing one V8 block every 39 seconds on one of their automatic lines. It takes me about 30 minutes to assemble one of my molds and have it ready to pour. I do not used lost foam at all in my blocks. Printed core technology is very expensive right now, but also easier in some ways. You need to know what to do and when and how it all effects end cost. If I spend more for printed cores it will save time and cost elsewhere, but is it enough? Do I eat some cost and reduce profit? It all needs accounted for. Tod |
05-06-2017, 11:42 AM | #25 | |
Re: New block
05-06-2017, 12:20 PM | #26 |
Re: New block
Alan |
05-06-2017, 12:41 PM | #27 | |
Re: New block
05-06-2017, 12:53 PM | #28 | |
Re: New block
Tod |
05-06-2017, 01:24 PM | #29 | |
Re: New block
05-06-2017, 02:28 PM | #30 |
Re: New block
Tod, please don't let the nay sayers discourage you. I think there would be as large a market for a flathead block as there is for the Model A block and maybe larger. I think it would be imperative that the new block use original internal parts. And i think the '39 -'48 block would be a LOT more desirable. I second the recomendation to get in touch with JohnLawson. Followed your progress on the Model A block, beautiful.
Tom |
05-06-2017, 02:57 PM | #31 | |
Re: New block
I have Model A orders to fill. Blocks and heads. Got the new OHV about ready too, with buyers waiting. Tod |
05-06-2017, 04:12 PM | #32 |
Re: New block
I'm not sure what the French blocks are going for now days or if folks are even purchasing any of them or not. The 8BA block would make more sense from its adaptability standpoint. Folks would need the pickup/Mercury pressings or maybe the 51 Mercury bell housing casting to adapt them to the early configuration types. If say $2500 per copy is do-able then there may be a market.
There will come a time when the old ones get played pretty well out but that may not be in my lifetime. I've purchased stuff like that before when an effort to make things like new was needed. There would be some market but I certainly wouldn't be the one to figure how much of one there'd be. The Aluminum large bore set up that Mark Kirby started has some promise but it seems to be in limbo right now. After the big slump in 2008 folks have been holding on to their purse strings a little tighter. Bottom line is that all of us would like to be able to go out and buy new parts like this but how many of us actually would is the mystery. |
05-06-2017, 04:17 PM | #33 |
Re: New block
Hmm, I didn't think there was a whole lot of naysaying or BS. Looked like a lot of people were intrigued and some offered suggestions. Oh well.
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget |
05-06-2017, 04:40 PM | #34 | |
Re: New block
Tod |
05-06-2017, 04:57 PM | #35 |
Re: New block
Folks that didn't know who you are before, including myself, just needed to know more. You are not the only person to bring this up in the past few years and some that have previously likely didnt have the skill sets you possess so you have to bear with us till some of us get more familiar with you and your capabilities. There are quite a few folks that frequent here that have a lot of years in the hobby and may be skeptical of folks they don't know so well yet.
05-06-2017, 05:18 PM | #36 | |
Re: New block
Alan |
05-06-2017, 06:07 PM | #37 | |
Re: New block
I think the video shows why the project was aborted. In addition to Mark Kirby there was an additional brain trust involved in the project and they re-engineered the whole package. There isn't much they left on the table that is not unique to the MCFH aluminum block; d-ports, smaller, relocated head studs, roller cam and unique guides, proprietary heads needed for new stud locations, revised oil pan, water pumps, front cover, cam gears, Fluiddamper balancer and on and on. It is for certain a complete work of engineering excellence, but all the upgrades made it out of reach ($$$$$) for the typical hobbiest and it's for that reason I think the project was shelved. Who wouldn't want one, but how many could pay for, or justify the cost?
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
05-06-2017, 09:12 PM | #38 |
Re: New block
Tod,
Ignore the gloom and doom folks. I am sure you will do your homework and make the best decision. Personally, I admire you for what you have done and am certain the future will bode well as long as you keep your finger in the flathead pie. |
05-06-2017, 09:26 PM | #39 | |
Re: New block
05-06-2017, 11:33 PM | #40 |
Re: New block
Tod
I have to say that at one time I thought the same thing, it would be just too expensive. However, the improvements in the casting and machining processes has changed my mind. Especially when a person ike yourself has the knowledge and wherewithal to attempt this at a reasonable cost. At present everything is available from the aftermarket, except the block. just think a nice 265 ci flathead with (8:1CR) with all stock parts in it except the pistons and block. Make a nice street engine for anyone. |
