Old 01-07-2012, 11:00 PM   #1
Fordors
Default All is not always as it appears.
Here's something I never knew existed:
http://s18.photobucket.com/albums/b1...t=P1010127.jpg
Fordors is offline   Reply With Quote
Old 01-07-2012, 11:38 PM   #2
59ab
Default Re: All is not always as it appears.
Never saw one either! It is a Holley not a Stromberg.
59ab is offline   Reply With Quote
Old 01-07-2012, 11:40 PM   #3
Butch11443
Butch11443's Avatar
To me it looks more like a Holley 94.
Butch
Butch11443 is offline   Reply With Quote
Old 01-07-2012, 11:43 PM   #4
TRUCK_RAT
TRUCK_RAT's Avatar
looks like it's a modified 94 to me. helluva good idea. take some machine work but it'd definitely be something nobody else had.
TRUCK_RAT is offline   Reply With Quote
Old 01-08-2012, 02:25 AM   #5
ken ct
It is a 94 8BA or later as it has the vacume port in the rear. I cant see any advantage over stock. Must have been a bugger to make the butter-fly plate fit right. OMO ken ct. A lot of work for nothing gained. Most likely a 48 truck base as it has the vac port but still has the provision for the throttle lever on the drivers side which only happened on 7HT and 8HT carbs.Kind of an odd base.
ken ct is offline   Reply With Quote
Old 01-08-2012, 10:09 AM   #6
38 coupe
38 coupe's Avatar
I have seen similar large butterflys on 4 barrel carbs that flow huge amounts of air. To gain airflow when you run this you would also need to machine the divider out of the manifold. With both the carburetor and manifold modified, it should flow a noticeable amount more air a wide open throttle, but will probably have lean mixture problems coming off idle.
Old 01-08-2012, 10:29 AM   #7
Ol' Ron
Ol' Ron's Avatar
Ken is right, Just remember air flow is determined by the venture size.
Old 01-08-2012, 10:57 AM   #8
38 coupe
38 coupe's Avatar
Venturi size is not the only thing that determines air flow. Friction with the walls of the carburetor and intake manifold along the whole passage are a very large player in how much air flow can be had. If you put the modified carburetor on a flow stand I would bet money (if I was a betting man) that if flows quite a bit better than a stock 94. In order to use this you would have to have a manifold that also could flow more, or the modification is useless. Also, the center section might be the larger bore Y Block carb.
I also would bet that someone got their inspiration for this from the old Holley 3 barrel carb.
Old 01-08-2012, 12:01 PM   #9
Scott H
Scott H's Avatar
I was gonna say photobucket has been around a long time...
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 01-08-2012, 01:08 PM   #10
Frank Miller
Frank Miller's Avatar
I bet performance at low speed is dismal due to loss of the venturi effect. It would be interesting t see the rest of the carb. I'm mostly guessing. Appreciate any thoughts along that line.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-08-2012, 01:44 PM   #11
Ol' Ron
Ol' Ron's Avatar
I was refering to flow through the carburetor. However I don't see much improvement in performance either. But I like the idea of experimenting to find a better way.
Old 01-08-2012, 07:28 PM   #12
Flathead
Flathead's Avatar
Was this from some old Track that required a "stock" carb?
Flathead is offline   Reply With Quote
