07-18-2021, 04:01 PM | #1 |
Motor for British turn signals in body behind the door
I am looking for a motor to operate the britissh turn signals on a 1936 Jensen/ford there were only 3 of these cars built and sent to America very rare
07-18-2021, 04:04 PM | #2 |
Re: Motor for British turn signals in body behind the door
I am looking for a motor to operate the turn signals on a 1936 Jensen / ford it is located behind the door and slides out of the body to indicate a turn
07-18-2021, 04:22 PM | #3 |
John, If it is the type I am thinking of, they are called "semaphores" or "trafficators" and are solenoid operated rather than motorised.
If they are as described, the two term I used above might help in your search. The chances are they were used across a broad spectrum of models. I just had a quick look on UK ebay and found a few listings. I searched using semaphore trafficator. Mart. |
07-19-2021, 07:05 AM | #4 |
John
As Mart has astutely pointed out, the "trafficators" you are asking about operate off of a electro-magnet. SO DO you have the bodies and the arm and are just missing the electro-magnet OR are you missing the complete set UP??? There "should" be an associated switch for them as well, are you missing that too? |
07-19-2021, 07:11 AM | #5 |
John
Here is a few shots of the inside of the trafficators (NOT necessarily the exact ones for your car) as you can see the magnet that operates the arm. ALSO a couple of switches that should be similar to what you "should" have!!!! |
07-19-2021, 07:24 AM | #6 |
07-19-2021, 07:46 AM | #7 |
Here is a set.
https://www.prewarcar.com/333677-sie...afficator-pair |
07-19-2021, 08:04 AM | #8 |
John
Here is MORE of the "type" of trafficator you are looking for, NOT sure of the dimensions you "need" BUT there are several pairs (mostly Lucas) which, "most likely", would have been on your car on Epay. YOU may have to either "alter" a pair that you get OR the car to fit ones that you find. I have been following these now for over 18 years and the last two to three years the prices have quadrupled for them and the switches. NOTE on all four pictures the "Chrome" ends that show on the outside. Pictures 2, 3 & 4 would be a "likely" candidate for you AS you could remove the "L" shaped mounting bracket OFF the back and use the remaining machine screw holes to mount to the inside of the body somehow!!!! |
07-19-2021, 08:07 AM | #9 |
NOTE the "Chrome" trafficators on this Jensen Ford behind the rear of the door
07-19-2021, 08:46 AM | #10 |
VWs used them. https://www2.cip1.com/ProductDetails...3%2D021%2DF12V
07-19-2021, 11:34 AM | #11 | |
Check with Art Knapp in Covina CA. He completed a total restoration of one of the three Jensens several years ago. This car is undoubtedly the best of the breed at this time. His phone number is 626 319 3853 Good luck |
07-19-2021, 12:24 PM | #12 |
JohnSorrell
You are welcome to email me IF you need or [email protected]. I have a brand new in the box set of Trico trafficators and switch that I bought a few years back that I know, style wise, are what you are seeking, not sure "size" wise if that would be the case BUT also know they were used in England, Holland, etc etc as the trafficators came from Holland and the switch from England. They are for one of our Euro Fords BUT I can send along pictures and measurements IF that will help you!!!! I found another NOS set of the same trafficators a year or so after mine for a fellow and his Dagingham Custom 35 Ford that is under restoration now, to my knowledge they fit his car perfectly!!!! |
07-20-2021, 09:12 AM | #13 |
thanks everybody mutch help
