10-10-2015, 09:17 PM | #1 |
drooping door handle
My drivers side door handle is a bit droopy I did a quick fix on my last v8 years ago by twisting the shaft. I can't remember which way I should twist it. Has anyone done this before and which way? Is it in the direction the handle turns or away from it?
I don't want to go to the trouble of overhauling the mechanism at the moment. Thanks GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
10-10-2015, 09:44 PM | #2 |
Re: drooping door handle
I would say away from it. If handle droops down, you would want to lift up to straighten it. (WAG only)
10-10-2015, 10:55 PM | #3 |
Correct.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
10-11-2015, 12:02 AM | #4 |
Thanks . I thought so. Just wanted the opinion of the knowlegable before I went messing with it.
GB
10-11-2015, 02:34 AM | #5 |
Try a new spring
10-11-2015, 02:51 AM | #6 |
MEMBER EMERITUS
10-11-2015, 04:48 AM | #7 |
try swapping handles from side to side, see if it changes the angle. the shaft twist sometimes.
10-11-2015, 07:23 AM | #8 |
would it be of value to heat it first? Since they come out so easily, I usually do this in a vice, thinking less strain on the mechanism. And I do heat them first, jic.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
10-11-2015, 10:01 AM | #9 |
A little heat can't hurt. Just don't discolor the stainless.
10-11-2015, 11:55 AM | #10 |
The shaft will twist without heat.
10-11-2015, 11:59 AM | #11 |
In combination with Swoop's suggestion, sounds like a win/win.
Alan |
10-11-2015, 01:05 PM | #12 |
10-11-2015, 01:48 PM | #13 |
Crescent wrench and a vise
10-11-2015, 06:04 PM | #14 |
Fix it with a new spring. If you twist it you will have to twist it back when the spring breaks and is replaced.
10-11-2015, 06:34 PM | #15 |
10-11-2015, 07:48 PM | #16 |
10-11-2015, 08:56 PM | #17 |
Replacing the spring alone may not solve the problem due to wear of the moving parts in the mechanism. Spring replacement may also require a twist of the shaft to eliminate the droop completely.
10-11-2015, 09:13 PM | #18 |
10-11-2015, 11:01 PM | #19 | |
I have bought NOS latch mechanisms in the hopes that these will give me good handle alignment. I intend to re-lube the mechanism with the best lube I can find to slow the wear process down.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
10-12-2015, 12:05 AM | #20 |
Thanks every one. My memory has been jogged...yes I used a crescent on my last v8 25 odd years back and no heat.
GB
