02-02-2017, 07:49 PM | #1 |
Assembly Plants and Body Numbers
Found these letters (if you can call them that) and numbers on the side rail of a February 1931 Fordor 165C
Can someone let me know where this car was made or what it stands for. The last picture is the way it in the car but put up all angles to help Thanks .... Last edited by Joop; 02-02-2017 at 08:00 PM. |
02-02-2017, 09:59 PM | #2 |
Re: Assembly Plants and Body Numbers
www.whidbeymodelaclub.com |
02-02-2017, 10:28 PM | #3 |
Thanks Gary
Checked Plucks site but nothing there for the question at hand, did go to Dave Sturges site on MAFCA but no answers either. |
02-03-2017, 09:47 AM | #4 |
Joop,
I have not seen anything like this before. The numbers and the other characters may have been done at two different times. Looks like a center punch and a small cold chisel were used for the odd characters. Regards, Dave |
02-03-2017, 01:42 PM | #5 |
should be more like this..
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
02-03-2017, 02:42 PM | #6 |
02-03-2017, 03:21 PM | #7 |
Don't know if this will help, but appears to me that the miss-stamped letters are "VH"
02-03-2017, 03:22 PM | #8 |
Car spend its live in the Detroit, MI area
02-03-2017, 05:21 PM | #9 |
Most of the Murray and Briggs bodies had a small tag either attached to front body sill or firewall. The Ford built bodies have the numbers stamped into the front Steel body sill (cross member). These numbers are production numbers for each assembly plant.
Dave |
02-05-2017, 02:55 PM | #10 |
This one has a MURRAY body tag
02-05-2017, 03:39 PM | #11 |
Could it be just an owner putting on "his" number just for ID purposes??
02-05-2017, 10:10 PM | #12 |
This must be the month for body number questions. Here is a link from the Model t site that should answer your question. Hope this helps.
https://www.mafca.com/downloads/Tech...y%20Number.pdf |
