08-06-2022, 03:15 PM | #1 |
Silicone gaskets
Does anyone produce silicone valve covers for the Model A? I also have a 1951 MG TD and there is a gentleman who produces some awesome tappet and valve covers that are leak proof and last forever.
08-06-2022, 04:03 PM | #2 |
Re: Silicone gaskets
Have you had trouble with your A valve cover leaking? I do not think silicone is available.
John
Welcome each day |
08-06-2022, 05:19 PM | #3 |
If you want to cut your own, you can buy sheets of silicone of different thicknesses and durometers at McMaster-Carr. Some of the sheets they sell are more tear resistant than others.
08-06-2022, 10:05 PM | #4 |
why are you having an issue with the side valve cover leaking?
It is a gasket that usually seals pretty good. the drain tube gaskets i have had some leaky ones. the drain back tube has copper washers on the bolts that need to be there or those could leak.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
08-06-2022, 10:22 PM | #5 |
Comes in a squeze tube, pick the colour of your choice.
08-07-2022, 06:38 AM | #6 |
08-08-2022, 01:29 PM | #7 |
I would use silicone sparingly. I have seen one too many engines ruined by using too much silicon gasket maker and plugging oil orifices when it comes loose. I have had good luck with The Right Stuff in other applications but I would never use silicone in a engine.
08-08-2022, 05:24 PM | #8 |
I don't use the regular silicone sealer, instead I use Ultra Black & no gasket.
08-09-2022, 07:01 AM | #9 |
If you use silicone gasket cement, designed for automotive use, and a gasket, use just a small amount, just enough to wet the surface of the gaskets. Use your finger to smear a small amount on the gaskets, just a light film.
If there is a small amount of oil film on the parts the silicone will not stick and will make removing the parts later on easier. Back in the day, grease was used as a gasket cement for race cars as they were taken apart after each race. It made it easier to remove the parts.
08-09-2022, 05:44 PM | #10 |
As far as using silicone…
